onesillyracer Posted May 17, 2007 Share Posted May 17, 2007 Any idea what this code is? Last week i installed an avo panel filter, but had major issues with getting the filter and airbox to sit correctly. the entire week the car idled somewhat weird, now I have a cel. I'm bringing the car to the dealer on monday if i cant get this issue figured out Link to comment Share on other sites More sharing options...
mickeyd2005 Posted May 17, 2007 Share Posted May 17, 2007 Check the MAF wires. Make sure it wasn't damaged. The AVO panel should be dry. Did you oil it? The MAF may have become contaminated. Link to comment Share on other sites More sharing options...
fishbone Posted June 20, 2007 Share Posted June 20, 2007 Same error code here. MAF wires ... what and where am I looking for? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 20, 2007 Share Posted June 20, 2007 It's the sensor on top of the air box. Did you install an aftermarket intake? Link to comment Share on other sites More sharing options...
fishbone Posted June 20, 2007 Share Posted June 20, 2007 No, I'm bone stock. The problem has been identified and fixed. It was Valvoline's doing! Symptoms: in the morning when I'd start her up, she'd act as if she'd be about to choke, then idle rough overall. This started happening about a week and a half ago. Well tonight I popped the hood open only to find that the clamps on the airbox were NOT hooked up. The airbox was open enough on the top for me to almost slip my pinky in there. I took out the sensor that rests directly on top of the airbox and cleaned it, it was pretty gunked up. Is this the MAF by chance? Looked like a diode. I hooked everything back up, disconnected the battery to clear the CEL and gave her a start. Sure enough she came to life and now idles sikly-smooth. First thing tomorrow I'm going to go over to Valvoline and give them a piece of my mind, putting them on notice that if anything turns up to pe wrong with my engine due to dust getting in there [i do live in an unpaved area], they're gonna pay me for a new Boxer. Those mofos almost cost me a brand new throttle body on my ex-Altima. Thank God it was under warranty, that would have been a 900 dollar repair. Basically they cleaned the MAF and the throttle body and managed to decalibrate it, so the car would idle at 1200 rpm. If you want something done right, you do it yourself! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 20, 2007 Share Posted June 20, 2007 That's the MAF sensor. Sometimes when swapping it to an aftermarket intake, it is either damaged or gunked up by the oil on the aftermarket filter. Link to comment Share on other sites More sharing options...
jazzymt Posted December 10, 2007 Share Posted December 10, 2007 The problem has been identified and fixed. It was Valvoline's doing! Symptoms: in the morning when I'd start her up, she'd act as if she'd be about to choke, then idle rough overall. This started happening about a week and a half ago. Well tonight I popped the hood open only to find that the clamps on the airbox were NOT hooked up. The airbox was open enough on the top for me to almost slip my pinky in there. Damn I love the internet! Got 2 P0171 codes in two days - couldn't figure out what the heck was going on...just put coilovers on, but knew that couldn't be the cause...unless... The douchebags @ Firestone must have opened up my air box to check my air filter when they did my alignment & they didn't close it back up = open air box, bad MAF readings & probably a dirty MAF. Will hit up Checker tonight for some cleaning solution, but I'm thinking this must have been the source of the problem. Thanx Mang! [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
hutru01 Posted May 8, 2008 Share Posted May 8, 2008 I got this code a few weeks ago for some reason. I took the CAI intake out and looked at the MAF sensor, nothing wrong with it at all....reinstalled and havent gotten the code again since. Its possible it could have gotten wet I suppose. Link to comment Share on other sites More sharing options...
stanghater Posted May 13, 2008 Share Posted May 13, 2008 i just go the p0171 in my wrx, it was a disconnected vac hose Link to comment Share on other sites More sharing options...
tommypenguin Posted July 25, 2008 Share Posted July 25, 2008 Got my first p0171 today, cruise control started blinking and check engine light came on. I will spray maf cleaner on it when I get home. Thanks lgt.com. Link to comment Share on other sites More sharing options...
Jon in CT Posted July 25, 2008 Share Posted July 25, 2008 i just go the p0171 in my wrx, it was a disconnected vac hoseP0171 is nearly always the result of an intake/vacuum system leak. Link to comment Share on other sites More sharing options...
tommypenguin Posted July 25, 2008 Share Posted July 25, 2008 I cleaned my maf, didn't do the job even though my maf needed to be cleaned, sure enough the 't' fitting under the intercooler had a hose blow off. Order has been restored to my lgt. Link to comment Share on other sites More sharing options...
underpowerd Posted July 26, 2008 Share Posted July 26, 2008 osr had a minor panel filter gasket issue Link to comment Share on other sites More sharing options...
SilverSeraphim Posted October 13, 2008 Share Posted October 13, 2008 Ah hah! P0171 triggered cause my boost gauge T splitter slipped out of the hose. Time to go buy a hose clamp. Clearly friction isn't doing it's job. Link to comment Share on other sites More sharing options...
st267 Posted February 5, 2013 Share Posted February 5, 2013 Finished a clutch job Sunday started the car up and it ran like hell. ROUGH.. barely idling, staled once. Finally threw the P 0171 code after about 5 miles of driving. I took 10 mins Monday night to quickly check the air box and hoses in sight. Low and behold, on that little blue T connector between the bottom front of the IC and the intake manifold, had one of the vacuum lines off. Reconnected it and the rest is history but really Subaru ? u could have put a 10 cent mini hose clamp on that bad boy? Thanks all for the input. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 5, 2013 Share Posted February 5, 2013 Finished a clutch job Sunday started the car up and it ran like hell. ROUGH.. barely idling, staled once. Finally threw the P 0171 code after about 5 miles of driving. I took 10 mins Monday night to quickly check the air box and hoses in sight. Low and behold, on that little blue T connector between the bottom front of the IC and the intake manifold, had one of the vacuum lines off. Reconnected it and the rest is history but really Subaru ? u could have put a 10 cent mini hose clamp on that bad boy? Thanks all for the input. I see your new here. Welcome. You should zip tie all the small vacume hoses, they are a issue with these cars. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
illusi0ns2 Posted June 22, 2013 Share Posted June 22, 2013 Just had this code myself. New short block in it from the dealer. Probably have maybe 450 miles on it. Checked it out didn't see anything that stood out so well have to have the dealer check their work. Link to comment Share on other sites More sharing options...
illusi0ns2 Posted June 23, 2013 Share Posted June 23, 2013 Mine may have been the famous t I read about on another post. One side was completely off. Fixed it now to get some miles on and see if it clears the cel Link to comment Share on other sites More sharing options...
abarnesDLGT Posted November 30, 2014 Share Posted November 30, 2014 Where are the vacuum hoses located ? I'm having the same problem but my idol is fine Link to comment Share on other sites More sharing options...
TheMonaLisa Posted February 8, 2015 Share Posted February 8, 2015 Had this happen to me tonight. I had zip tied my blue T so that was ok, but where the blue T line connects to the manifold popped off. Tricky cause its kinda hidden in there. Link to comment Share on other sites More sharing options...
gaethzac000 Posted August 1, 2017 Share Posted August 1, 2017 So my car is throwing the same code and I cleaned my MAF and that didn't do it. Looking around for vac leaks and not seeing anything in plain sight. Also not really sure where to look. Any of you guys have pictures of where your hoses we're disconnected? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 5, 2017 Share Posted August 5, 2017 Here's the blue T on the back side of the intake manifold. http://i185.photobucket.com/albums/x40/92Si/DSCN4695_zps3aa22b1e.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN4750.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
