Guest heightsgtltd Posted September 1, 2008 Share Posted September 1, 2008 Fuse blown? Link to comment Share on other sites More sharing options...
newbwrx Posted September 1, 2008 Share Posted September 1, 2008 I checked all the fuses and found that the audio fuse was blown. I have since replaced it, but nothing works still. Link to comment Share on other sites More sharing options...
newbwrx Posted September 1, 2008 Share Posted September 1, 2008 bump for help. Link to comment Share on other sites More sharing options...
iNVAR Posted September 25, 2008 Share Posted September 25, 2008 not a solution for your problem, but after testing with a voltmeter today, i can tell you that RED/YELLOW is not a constant 12V. that is an ignition 12V wire. constant 12V would be BLUE/RED. will have pictures of my gauges installed in a little bit Link to comment Share on other sites More sharing options...
noswad Posted September 26, 2008 Share Posted September 26, 2008 Here's my boost gauge install how-to: http://jsalmi.com/car/boostgauge/ John- what type(brand) of boost gauge did you use? It looks like it matches the dash lights perfectly. Is there dimming control on the gauge? Looks great, great write-up. Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? -George Carlin Link to comment Share on other sites More sharing options...
91bulldog Posted October 11, 2008 Share Posted October 11, 2008 sup guys, I'm installed my prosport elec boost gauge and i came across a problem. I followed lgt dave post. as of now the boost is sitting at -25 and does not go anyway even when the car is on the road. Can someone help me.....Please... I did the follow. Am i missing anything? Red wire from both sensor & Gauge to Red/Yellow White wire from Gauge to Red/yellow Black wire from both sensor & Gauge to Black/yellow white wire from sensor to green wire on gauge Link to comment Share on other sites More sharing options...
iNVAR Posted October 11, 2008 Share Posted October 11, 2008 which gauge do you have exactly? http://prosportgauges.com/faqs.aspx Q: I lost my instructions how do I wire the performance Series gauge? A: Black –Ground Red - 12v ign. power-meaning power when the ignition is on. White- 12v ign. power Orange-Headlight switch. Green - Sender The above/below wiring will result in white during the day and color (amber or Green) at night. Q: How Do I wire my Premium Series(Peak/Warning) Gauges? A: Red -Constant 12v power Black-Ground White-12v ignition power Orange-headlight switch Green –Sender also double check your vacuum line to make sure it's not kinked. Link to comment Share on other sites More sharing options...
vodoo-chile Posted April 19, 2009 Share Posted April 19, 2009 Alright, bringing this back. I think I have everything figured out. What I don't know is which wire on the back of the trip computer do we hook up the orange wire to if we are wanting amber at night? Here is what I understand so far: Wires from guage/to wires in trip computer Red to red/blue (constant 12v) white to red/yellow(ignition 12v) black to black/yellow(ground) orange to ????(headlight switch) Any help is greatly appreciated as I am attempting to do this on my one day off tomorrow. Thanks, Kyle Link to comment Share on other sites More sharing options...
kongzilla Posted March 19, 2011 Share Posted March 19, 2011 Sorry to bring back an old thread but does this allow the gauge to dim also if your dimming your lights. Link to comment Share on other sites More sharing options...
MDKSDMF Posted March 20, 2011 Share Posted March 20, 2011 yeah the orange threw me off too.. Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 10, 2011 Share Posted April 10, 2011 Here's my boost gauge install how-to: http://jsalmi.com/car/boostgauge/ Old thread, I know, but I just used John's write up to install my boost gauge. Thanks so much for writing and leaving it up. Now on to the the two fingers of The Glenlivet. Link to comment Share on other sites More sharing options...
iNVAR Posted April 10, 2011 Share Posted April 10, 2011 I suggest not using the trip computer wire for power. A more elegant solution is to use a fuse tap directly from the fuse box that is tied in with your power windows. That way, your gauges won't be on when you have the accessories (i.e. radio, cigarette lighter, etc.) on. They will only come on when your dashboard lights up as well. Makes more sense that way. http://legacygt.com/forums/showthread.php/gauges-wiring-ignition-12v-97117.html?t=97117&highlight=fuse+tap Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 10, 2011 Share Posted April 10, 2011 I did use the fuse tap but put in in the ACC fuse slot. I'll look for the one for the windows. http://i251.photobucket.com/albums/gg313/civexsi/spec%20B%20Journal/car021-1.jpg Link to comment Share on other sites More sharing options...
subi_snipe223 Posted April 28, 2011 Share Posted April 28, 2011 Subscribed for future install Link to comment Share on other sites More sharing options...
GingerFlyer Posted October 15, 2014 Share Posted October 15, 2014 I installed a glow shift gauge or something like that. Got power from the 12v power beneath the climate control. Vacuum run behind the fender liner into the cabin. Worked great. Kinda difficult to find the grommet from the cabin though Link to comment Share on other sites More sharing options...
optyks Posted October 24, 2014 Share Posted October 24, 2014 When you guys are talking about connecting to existing wires, how the hell are you tapping into the wire? Stripping the wire and wrapping it around? That seems ghetto as **** to me. I'm trying to hook up my AFR gauge but i'm stuck with the wiring and figured I'd ask in here since it's very similar. If you use a fuse tap, can you take out one of the existing fuses and tap into that slot with the additional gauge and have everything work fine? Link to comment Share on other sites More sharing options...
GingerFlyer Posted October 29, 2014 Share Posted October 29, 2014 Either way works, just make sure you are getting the right amount of power. There are also devices which splice into a wire without having to cut the insulation yourself leaving a nice clean connection. I've heard they done always work very well but I've never tried them personally. Link to comment Share on other sites More sharing options...
Markbo Posted November 25, 2014 Share Posted November 25, 2014 Which of these wiring methods ensures the gauges will dim with the dash lights? Link to comment Share on other sites More sharing options...
