hutru01 Posted May 23, 2007 Share Posted May 23, 2007 If you find it to be a rotor issue. thekingofparts has OEM front rotors for around $60 ea. I guess I will know when I change the pads..... Link to comment Share on other sites More sharing options...
jagcars26 Posted May 24, 2007 Share Posted May 24, 2007 Less dust than stock? Yep,,alot less IMO Link to comment Share on other sites More sharing options...
HansGT Posted May 25, 2007 Share Posted May 25, 2007 Yep,,alot less IMO Yaahoo! Link to comment Share on other sites More sharing options...
Waxiboy Posted May 25, 2007 Share Posted May 25, 2007 I guess I will know when I change the pads..... Most likely brake material deposit on the rotor surface. Personally, I only feel the shaking when braking lightly. Try braking hard several times and that should clean up your rotor. I will be getting slotted DBAs soon Link to comment Share on other sites More sharing options...
zach999 Posted May 27, 2007 Share Posted May 27, 2007 I just completed putting HPS pads, new fluid on my LGT and there is a world of difference in the initial bite and the brake feel but I still wonder how much better the brakes can actually stop your car. From 60-0 with HPS pads are we stopping under 120 ft now, etc. Also I too have a rumble everytime I brake that occurred before I replaced my OEM pads. The rotors looked clean and fine so I am a little perplexed. The rumbling seems to get a bit better when braking hard. I had my rotors machines once at 10K miles and now am at 23K and think the rotors may need it again. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 27, 2007 Share Posted May 27, 2007 you didn't cut or refinish them with the new hps? Link to comment Share on other sites More sharing options...
Chris Godawski Posted May 27, 2007 Share Posted May 27, 2007 My Hawk HPS pads (F&R) go on tomorrow morning. I am also putting on the Stoptech front slotted rotors. I figured while i am tearing the thing apart, i can put something in that will visually state that i made a change in the brakes, and also anything that will improve stopping is huge for me. I still drive my family in this car sometimes. I am convinced that this has to be better than stock, because for some reason subaru is not making the brake setups their car demand (my bro had a wrx and it had same problem, drove STI, and that was good stopping power). I unfortunately don't have the cash for the STI swap Link to comment Share on other sites More sharing options...
HansGT Posted May 31, 2007 Share Posted May 31, 2007 I had my rotors machines once at 10K miles and now am at 23K and think the rotors may need it again. Don't do it again. You are loosing material each time...taking away the ability of the rotor to absorb heat. Get new ones...OEM fronts are like $60 ea. Link to comment Share on other sites More sharing options...
zach999 Posted June 17, 2007 Share Posted June 17, 2007 Dealer confirmed the rumbling in my rotors was because they were warped. They did machine the rotors (again) and the car brakes fine now...no rumble. So I have had the rotors machined 2x in 23K miles but they still look pretty thick. I think they only machine a very thin sliver off the rotors so I think I should be good for at least another 10-20K miles. Brakes are weird in that their is a risk of glazing the pads and rotors which can reduce breaking ability. I recently had a Ford escape installed with new performance pads and brembo rotors. I put the pads on first myself and then the suv stopped great. then i did the rotors a month later and the car stopped great. 2 weeks later the brake booster started hissing. i had the dealer repkace this part and the brakes never worked the same. The dealer kept on claiming it was the inferior pads to the Ford OEM pads and not their booster install. At the end of the day, I had the rotors machined and the pads replaced and the suv stops great again. the dealer claimed my rotors and pads were glazed. Not sure how the dealer could glaze my pads and rotors during test drives...or am I freakin crazy. Wondering what type of braking can "glaze" the rotors and pads? Link to comment Share on other sites More sharing options...
hutru01 Posted June 18, 2007 Share Posted June 18, 2007 ^ I have that rumble right now with mine. I am getting ready to go with either the HPS or Ceramics... Link to comment Share on other sites More sharing options...
nino2138 Posted June 23, 2007 Share Posted June 23, 2007 I just purchased Hawk HPS front pads from "The King of Parts" for $82 including shipping. Awesome deal. I have heard some great reviews about these pads from a couple of people I know that have them on their Lexus cars (GS400 & IS300). They say the dusting is low and the bite is great. I'll see when I get these babies in. I have the Endless Vita Nuova Pads in the front right now. The seem to be okay. The only problem I have with them is it seems like every time I make a panic stop, they leave so much debris on my rotor that it makes them feel warped. Then I have to clean off the rotors using the same procedure I bedded the pads in with: Three to four moderate decelerations from 35-40mph then let the pads rest. These pads were supposed to withstand heat much better than they do. So now I'll give the Hawks a try. Link to comment Share on other sites More sharing options...
