Effin Ponderous Posted May 1, 2007 Share Posted May 1, 2007 Just picked up a set of Magnaflows with pre-welded ends to bolt up to my stock exhaust. While it sounds great, the tips are about an inch to far out and I want to loose the rice look. Can I simply cut an inch from before the Y and re-weld, or do I need to cut the pipe at each muffler. I'm worried that pulling it back before the Y will put to much tension on the hangers...(not you Hanger ) Pics to follow, but I think they do stick out too far. Link to comment Share on other sites More sharing options...
bmorrisj Posted May 1, 2007 Share Posted May 1, 2007 you have to chop the pipes at the mufflers and re-weld/adjust the hangers Link to comment Share on other sites More sharing options...
Spec B Posted May 2, 2007 Share Posted May 2, 2007 I think you could probably solve the issue if your local muffler shop relocates the hangers and/or re-does the pipe from the muffler to the Y. I don;t think you should chop the tip. Are they loud?? Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 2, 2007 Share Posted May 2, 2007 Pictures Denial is your best friend Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 2, 2007 Author Share Posted May 2, 2007 I'll post up pics tomorrow. I drove over 500 miles today with them (central Jersey to Frederick MD and back) and loved the cruising sound. Low tone and no drone. Kind of hard to explain further but at low revs it almost sounds like it is congested. I think the mid pipe catless, or maybe the resonator removal would clean it up a little. I gotta try something though because they do look a little ricey sticking out. Link to comment Share on other sites More sharing options...
diamondgraymetallic21 Posted May 3, 2007 Share Posted May 3, 2007 Take a rubber mallet and just bang them back under. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 3, 2007 Author Share Posted May 3, 2007 Take a rubber mallet and just bang them back under. :eek: Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 3, 2007 Author Share Posted May 3, 2007 Some pics and a bad quality sound clip on you tube...did the tuck trick from another thread and it helped alot. [ame=http://www.youtube.com/watch?v=-oDPimytH2w]YouTube- Broadcast Yourself.[/ame] Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 3, 2007 Share Posted May 3, 2007 Whats the tuck trick? Thats not too bad. Denial is your best friend Link to comment Share on other sites More sharing options...
Spec B Posted May 3, 2007 Share Posted May 3, 2007 I think he is referring to the Megan "tuck".. http://www.legacygt.com/forums/showthread.php?t=59679 Effin, they don't look that bad..but you should get them adjusted about 1". I am getting my Magnaflows installed this weekend, I can't wait! I think they sound GREAT! I was worried it would be raspy..but is seems like it is nice and deep. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 3, 2007 Author Share Posted May 3, 2007 +1 on the megan tuck. Totally not raspy, almost not, not raspy enough? Link to comment Share on other sites More sharing options...
Hanger Posted May 3, 2007 Share Posted May 3, 2007 my Prodrive stick out about that much, everyone who seen it said it looks better that way, just stick out enough to see the Prodrive lettering on top ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Hanger Posted May 3, 2007 Share Posted May 3, 2007 Just picked up a set of Magnaflows with pre-welded ends to bolt up to my stock exhaust. While it sounds great, the tips are about an inch to far out and I want to loose the rice look. Can I simply cut an inch from before the Y and re-weld, or do I need to cut the pipe at each muffler. I'm worried that pulling it back before the Y will put to much tension on the hangers...(not you Hanger ) Pics to follow, but I think they do stick out too far. lol i know i get confused when people mentioned "hanger" in their threads, but i smarted up and got used to it ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
