BigT Posted April 30, 2007 Share Posted April 30, 2007 I need some help. Some how the wheel well plastic on my car came undone and got partially eaten by my wheel. It was pretty gross. it is now being held together by part of a hanger. Can I just rip it off and wait until I get a new one from the st3ealership? Is there stuff there that need protecting? FYI My HIDS ballasts are there as well. Is this a problem? Link to comment Share on other sites More sharing options...
CSTMIZR Posted April 30, 2007 Share Posted April 30, 2007 You'll be just fine. My recommendation is to not "rip it off".......but to tactfully remove the minimum area of the, now offending, wheel well covering. I recommend a "tin snip" or industrial scissors, just cut out the least that you can, and if you are very concered; neatly placed plastic, some tucking and some tape should hold you over for the duration of the wait (proper service expected). Aftermarket items should be paid special attentin to, product and install quality vary, so beware. Hope that helps. Link to comment Share on other sites More sharing options...
BigT Posted April 30, 2007 Author Share Posted April 30, 2007 Definetely. Thanks! Link to comment Share on other sites More sharing options...
bskey Posted April 30, 2007 Share Posted April 30, 2007 If warranty is covering this ask the dealership for a loaner as you are concerned about splashback getting into your electronics. life in spin cycle..... Link to comment Share on other sites More sharing options...
