eles1 Posted September 19, 2007 Share Posted September 19, 2007 what is wrong with me?? I tried and tried and tried and tried this method but NOTHING out of the ordinary happens let alone showing me codes. here is what I am doing get in car close door, put key in turn on turn p lights on push the trip a/b stalk 4 times lights off push 4 times lights on push 4 times an VOILA not a damn thing happens My car is an 06 auto Where the hell did you get those instructions?!? You need to plug the two small connectors inside the fuse-box area together to get the car to read codes... has nothing to do with the parking lights!! Link to comment Share on other sites More sharing options...
tigersan Posted September 20, 2007 Share Posted September 20, 2007 Where the hell did you get those instructions?!? You need to plug the two small connectors inside the fuse-box area together to get the car to read codes... has nothing to do with the parking lights!! Got them from the link in post #6, apparently the 06 and up don't use those connectors. Link to comment Share on other sites More sharing options...
eles1 Posted September 20, 2007 Share Posted September 20, 2007 Got them from the link in post #6, apparently the 06 and up don't use those connectors. I see, that's news to me. Good luck... Link to comment Share on other sites More sharing options...
moawdtsi Posted February 5, 2012 Share Posted February 5, 2012 what is wrong with me?? I tried and tried and tried and tried this method but NOTHING out of the ordinary happens let alone showing me codes. here is what I am doing get in car close door, put key in turn on turn p lights on push the trip a/b stalk 4 times lights off push 4 times lights on push 4 times an VOILA not a damn thing happens My car is an 06 auto I had an issue with this tonight but I used the stalk to turn the lights all the way on and then off and it worked on my '07 (per these instructions: http://forums.nasioc.com/forums/showthread.php?t=1504038) Using the parking light switch on the steering column did not work for me. Link to comment Share on other sites More sharing options...
