onesillyracer Posted April 24, 2007 Share Posted April 24, 2007 I did a quick search and really didnt find anything comparing height and spring rates for both the swift and pink lowering springs. Would anyone have that info to share? I have swifts currently, but have in transit pinks w/bilsteins, so im just trying to find some info. Thanks! Link to comment Share on other sites More sharing options...
Rambo Posted April 25, 2007 Share Posted April 25, 2007 Your new pinks with bilstiens will ride better! Link to comment Share on other sites More sharing options...
HansGT Posted April 25, 2007 Share Posted April 25, 2007 Racecomp (aka GTWORX tuning) recommend Swift. They told me they feel very very similar to Pinks on Bilsteins. Myles has bottomed out his Spec B on Pinks although many others I've spoken to do not have an issue. Given the spring rate the Pinks should be a little more comfortable, but in a performance environment Swifts will be better. STI Pinks (@$400) 3.9kg/mm F, 5.9kg/mm rear drop is 15mm all the way around on Bilsteins, although pictures and reviews suggest it's closer to 20mm. Swifts (@$280) Specifications: 4F007 MY05 Legacy GT Wagon (BP6) Drop - F:-25mm, R:-15mm (Bilsteins) Drop - F:-32mm, R:-25mm (USDM KYB) Rate - F:4.3kg/mm, R:6.6kg/mm 4F008 MY05 Legacy GT Sedan (BL6) Drop - F:-25mm, R:-15mm (Bilsteins) Drop - F:-32mm, R:-25mm (USDM KYB) Rate - F:4.3kg/mm, R:6.6kg/mm Check this out.... http://legacygt.com/forums/showthread.php?t=59582 Link to comment Share on other sites More sharing options...
Polo08816 Posted June 20, 2022 Share Posted June 20, 2022 Racecomp (aka GTWORX tuning) recommend Swift. They told me they feel very very similar to Pinks on Bilsteins. Myles has bottomed out his Spec B on Pinks although many others I've spoken to do not have an issue. Given the spring rate the Pinks should be a little more comfortable, but in a performance environment Swifts will be better. STI Pinks (@$400) 3.9kg/mm F, 5.9kg/mm rear drop is 15mm all the way around on Bilsteins, although pictures and reviews suggest it's closer to 20mm. Swifts (@$280) Specifications: 4F007 MY05 Legacy GT Wagon (BP6) Drop - F:-25mm, R:-15mm (Bilsteins) Drop - F:-32mm, R:-25mm (USDM KYB) Rate - F:4.3kg/mm, R:6.6kg/mm 4F008 MY05 Legacy GT Sedan (BL6) Drop - F:-25mm, R:-15mm (Bilsteins) Drop - F:-32mm, R:-25mm (USDM KYB) Rate - F:4.3kg/mm, R:6.6kg/mm Check this out.... http://legacygt.com/forums/showthread.php?t=59582 Is there some reason someone is not able to use the Swift wagon (4F007) on a sedan? Link to comment Share on other sites More sharing options...
Polo08816 Posted June 25, 2022 Share Posted June 25, 2022 I plan to replace the suspension on a 2008 Subaru Legacy GT 5EAT Sedan. I see that Swift offers the 4F008 Sport Springs for the Sedan and the 4F007 Sport Springs for the Wagon. Can the 4F007 Sport Springs for the wagon be installed on a Sedan? They appear to be the same spring rate so I'm wondering how longer the 4F008 rear springs are for the wagon and how much higher the Sedan would sit in the rear? Also, are the front springs of the 4F007 and 4F008 the same? Link to comment Share on other sites More sharing options...
yellowspirit Posted August 3, 2022 Share Posted August 3, 2022 On 6/25/2022 at 10:49 AM, Polo08816 said: I plan to replace the suspension on a 2008 Subaru Legacy GT 5EAT Sedan. I see that Swift offers the 4F008 Sport Springs for the Sedan and the 4F007 Sport Springs for the Wagon. Can the 4F007 Sport Springs for the wagon be installed on a Sedan? They appear to be the same spring rate so I'm wondering how longer the 4F008 rear springs are for the wagon and how much higher the Sedan would sit in the rear? Also, are the front springs of the 4F007 and 4F008 the same? The answer is yes - I did it. Link to comment Share on other sites More sharing options...
