cwmiller Posted April 22, 2007 Share Posted April 22, 2007 17x8 with a +40mm offset, will they fit on an outback xt with stock 225/55r17 tires? Link to comment Share on other sites More sharing options...
NSFW Posted April 22, 2007 Share Posted April 22, 2007 I don't know, but if you can tell me the offset of the stock OB wheel, I can do a little math and perhaps give you a thumbs-up / thumbs-down. Link to comment Share on other sites More sharing options...
fweasel Posted April 22, 2007 Share Posted April 22, 2007 I don't know, but if you can tell me the offset of the stock OB wheel, I can do a little math and perhaps give you a thumbs-up / thumbs-down. Nice avatar... I told him we already got one... :lol: ignore him, he'll go away. Link to comment Share on other sites More sharing options...
crayzd Posted April 22, 2007 Share Posted April 22, 2007 I put some Motegi Track Touge 18x7.5 with a 45mm offset on my car and they fit fine event with the Tien S-Tech springs, no rubbing at all. Not that it helps you but I thought I would offer the info. Oh yea, I have 225/40ZR18 Tires. Link to comment Share on other sites More sharing options...
cwmiller Posted April 22, 2007 Author Share Posted April 22, 2007 stock is 17x7 +48mm. I believe they will stick out about +21mm. I don't know if i have enough room as that is almost an inch. Link to comment Share on other sites More sharing options...
NSFW Posted April 23, 2007 Share Posted April 23, 2007 The outside of the RIM will move out 8mm due to the offset plus 12mm due to the wider rim... But since the tires are going to be the same, then you're only going to lose 8mm of clearance along the outer (tread) portion of the tire. Just some food for thought. My guess is it will be OK in the back but borderline in the front. (You probably guessed that already.) 225 is kinda narrow for an 8" wheel by the way, here's an example on an LGT: http://www.legacygt.com/forums/showpost.php?p=684629&postcount=4 Link to comment Share on other sites More sharing options...
Xenonk Posted April 23, 2007 Share Posted April 23, 2007 it will be flush with the fender, it's doable, but you may need to roll your rear fenders for the XT. Keefe Link to comment Share on other sites More sharing options...
Prime Power Posted January 29, 2008 Share Posted January 29, 2008 Did you ever see if these will fit. I want some new rims with the same dimensions. Please let me know. Thanks Link to comment Share on other sites More sharing options...
team23jordan Posted February 1, 2008 Share Posted February 1, 2008 it'll fit Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
Prime Power Posted February 1, 2008 Share Posted February 1, 2008 Is the offset enough to where I should be concerned about the bearings? Link to comment Share on other sites More sharing options...
