SC GT Posted April 3, 2007 Share Posted April 3, 2007 I Google translated, and it looks like this guy used a GT-R rotor and it worked with just bracket, no messing with the parking brake shoes or the inner diameter of the hub. Is this right? http://www32.ocn.ne.jp/~nari_hp/diy/brake-r/brembo-r_1.html Link to comment Share on other sites More sharing options...
mickeyd2005 Posted April 3, 2007 Share Posted April 3, 2007 I didn't translate it, but does the BH/BE have the same brakes as the BP/BL? Link to comment Share on other sites More sharing options...
SC GT Posted April 3, 2007 Author Share Posted April 3, 2007 I didn't translate it, but does the BH/BE have the same brakes as the BP/BL? I'm pretty sure its the same as the BP/BL and WRX. Link to comment Share on other sites More sharing options...
Mines Posted April 3, 2007 Share Posted April 3, 2007 the wrx and our car have diff rear brakes Link to comment Share on other sites More sharing options...
apexjapan Posted April 3, 2007 Share Posted April 3, 2007 It is 2mm wider on the inside, the guy is claiming that the side brake works ok if you pull the lever up as far as it can go. But I would be nervous about actually parking it on a steep hill or other situation. Cheers, Paul Hansen http://www.sevenphotos.com Link to comment Share on other sites More sharing options...
