DPSubie Posted April 2, 2007 Share Posted April 2, 2007 I've heard that air intakes made for the older (98-99) impreza will fit on the 00-04 Legacy. Has anyone done this mod or know if it actually true? With the lack of parts for 00-04 Legacy I was thinking about going this route. Any input would be great. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 2, 2007 Share Posted April 2, 2007 I dont see why it wouldnt, but I havent done it. Link to comment Share on other sites More sharing options...
rougeben83 Posted April 3, 2007 Share Posted April 3, 2007 You'll need the intake made for the 00-01 RS's if yours uses MAP like the later BE's (like my 03). If you have an MAF, you can use the 98-99 RS intakes. Link to comment Share on other sites More sharing options...
DPSubie Posted April 3, 2007 Author Share Posted April 3, 2007 Do you have any idea how I can find out which one I have on my 01. I did some searching on here but didn't see much. Link to comment Share on other sites More sharing options...
rougeben83 Posted April 4, 2007 Share Posted April 4, 2007 Easy. See if you have a plastic tube with wires coming out of it that is before the big plastic square that leads into the intake and throttlebody. That's your MAF. If you don't have one, you have a MAP engine. Link to comment Share on other sites More sharing options...
DPSubie Posted April 4, 2007 Author Share Posted April 4, 2007 Awesome thanks for the info guys. It's just kind of weird that if the intakes made for the 2.5 RS work for the Legacy, why aren't the cross referenced. It would make sense to me, but oh well. Link to comment Share on other sites More sharing options...
Jonathan Posted April 11, 2007 Share Posted April 11, 2007 Prior to going with the Manifold Absolute Pressure (MAP) system, Subaru used the older Manifold Air Flow sensor (MAF). Subaru started using the newer MAP setup on their Japanese-built Impreza in 1999 (technically in late 1998 as a 1999 model year), but the US-built Legacys and Outbacks did not switch over to the newer setup until the 2000 model year. The reason why they didnt all convert at the exact same time is perhaps most likely because they had a large inventory of the older Phase-I EJ25 2.5 liter engines, and the older model Legacys were designed for this engine. The 2000+ Model year Legacys used the Phase-II EJ25 engine blocks, and MAP system, just like the Japanese built models. Link to comment Share on other sites More sharing options...
DLC Posted April 13, 2007 Share Posted April 13, 2007 The Cobb intake will definitely work. http://legacycentral.org/images/cobb/cai/installed.jpg Link to comment Share on other sites More sharing options...
kavolta Posted October 9, 2007 Share Posted October 9, 2007 Cobb is the way to go, definitley Link to comment Share on other sites More sharing options...
