ERLoft Posted March 29, 2007 Share Posted March 29, 2007 Ok, gotta make this one quick. I installed H3 foglight HID's last week. No problems. Today I finish installing H7 & 9005's. (One ballast was bad, that had been for a 9005, getting it replaced, but I don't think it's related.) So, I used a relay harness on the H7's. Now, when I turn on the low beam H7's and the foglights, I get the high beam indicator flashing. Kinda annoying. Especially since it seems that what I wired my ProSport Boost gauge amber switch to, so if flashes as well. Any ideas on what could be the cause? I had initially though that this was an indicator of a bulb out, as the passenger's side H7 isn't connected since there's a relay, but seeing as how it doesn't flash if the foglights are off, I'm not so sure. Thanks for any help! 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Xenonk Posted March 29, 2007 Share Posted March 29, 2007 sounds like it's not drawing the correct amps.. Keefe Link to comment Share on other sites More sharing options...
Rambo Posted March 29, 2007 Share Posted March 29, 2007 You did dis-able the daytime running lights right?? I put hid's on mine no problems! Link to comment Share on other sites More sharing options...
ERLoft Posted March 29, 2007 Author Share Posted March 29, 2007 Yes, DRL are disabled. 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
ERLoft Posted March 29, 2007 Author Share Posted March 29, 2007 sounds like it's not drawing the correct amps.. How would that be and how to solve it? Any ideas? 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
VXCL Posted March 30, 2007 Share Posted March 30, 2007 what you need to do is to go back to stock and then one by one add your new setup components and narrow the problem down. one step at a time. you get an answer real quick as to who the cuplrit is. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
ERLoft Posted April 4, 2007 Author Share Posted April 4, 2007 Well, just a quick update... The ballast was my own stupidity. No actual problems, the high beams work fine. It seems that lo beams & fogs aren't playing nice. I'm thinking I'll install a relay for the foglights and see where that gets me... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
edkwon Posted April 5, 2007 Share Posted April 5, 2007 Thats weird, what kind of wiring harness did you HID kit come with? My McCullogh kit was all plug n play with the stock wiring harness and fogs function on mine like they normally do. Link to comment Share on other sites More sharing options...
ERLoft Posted April 5, 2007 Author Share Posted April 5, 2007 Full HID across the board on your setup Ed? There's another wiring relay harness somewhere if I can just figure it out. I also might try removing the relay as well to see if the problem is in part that the car doesn't think anything's plugged into the passneger's side low beam. Either that or a resistor for the stock wiring harness to make it think that there's a light there. Anyone have any idea how many ohms the resistor would need to be, or know how to figure it out? Thanks! 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
lilbrudder Posted March 4, 2010 Share Posted March 4, 2010 Thread revival time! I have this problem now, was there ever a solution to it? Link to comment Share on other sites More sharing options...
ERLoft Posted March 5, 2010 Author Share Posted March 5, 2010 Been a while, but I believe what got this taken care of for me is that I switched my foglights to fully independent operation. Search for the foglight mod I think... 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
bmacog Posted April 8, 2010 Share Posted April 8, 2010 I had the same issue when I converted my high beams to HID's. I used deer killer's fully independent fog light mod and it fixed the issue. I would try that. Link to comment Share on other sites More sharing options...
