NSFW Posted March 27, 2007 Share Posted March 27, 2007 Does anyone make coilovers that can be set to stock height? I ask because the stock height is marginal during the winter, mostly due to a couple of parking lots I frequently use when snowboarding... but for the rest of the year I could happily go quite a bit lower. Thanks! Link to comment Share on other sites More sharing options...
Bigkahuna808 Posted March 27, 2007 Share Posted March 27, 2007 I need the same thing, maybe even raise the height of daily, and lower for race day Link to comment Share on other sites More sharing options...
RochNY91TSI Posted March 27, 2007 Share Posted March 27, 2007 Tein flex are pretty close to stock height. I never measured, but from guessing on the appearance alone I'd say that they're within a half inch of stock height Link to comment Share on other sites More sharing options...
Boostjunkie Posted March 27, 2007 Share Posted March 27, 2007 Most coilover systems for the LGT with separate height and preload adjustments can be run at stock height. I know that the Megan Racing LGT coilovers can be setup to run stock ride height, and as the previous poster mentioned, you can do the same thing with Tein Flex's as well. Cusco Zero 2, GP Moto and a least a few others should be able to do the same thing. If you want to keep your LGT's stock ride height or raise it for winter driving, then the new MR Outback coilovers will work perfectly. Link to comment Share on other sites More sharing options...
