sofi Posted March 26, 2007 Share Posted March 26, 2007 Hey guys, I've been looking all over this site...Does anyone know what 1320 or 0-60 times are like for LGTs equipped with the avo380:confused: I've seen plenty of dyno charts but no stats on times. Anyone with a 380 speak up! Link to comment Share on other sites More sharing options...
wukindada Posted March 26, 2007 Share Posted March 26, 2007 From what I recall the size is very close to a 18g so times should be about the same;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
noam Posted March 26, 2007 Share Posted March 26, 2007 From what I recall the size is very close to a 18g so times should be about the same;)Has anyone posted times for an 18g setup? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 26, 2007 Share Posted March 26, 2007 I hope to have times in July. Unfortunately it will be hot then. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
sofi Posted April 1, 2007 Author Share Posted April 1, 2007 From what I recall the size is very close to a 18g so times should be about the same;) What are times like for the 18g? 20g? Link to comment Share on other sites More sharing options...
turbo2nr Posted April 1, 2007 Share Posted April 1, 2007 GT28.....AKA new "Disco Potato" AKA, AVO 350, or 380 or whatever they now call it. It's one of the most popular turbos in the world for street use on a 4banger. You can't go wrong for street use. Link to comment Share on other sites More sharing options...
sofi Posted April 2, 2007 Author Share Posted April 2, 2007 You can go wrong for street use. Link to comment Share on other sites More sharing options...
turbo2nr Posted April 2, 2007 Share Posted April 2, 2007 can't go wrong whoops Link to comment Share on other sites More sharing options...
sutter2k Posted April 2, 2007 Share Posted April 2, 2007 ^^ Posts can be edited Link to comment Share on other sites More sharing options...
NSFW Posted April 16, 2007 Share Posted April 16, 2007 Best figures I've been able to collect say the 18G is 39 lb/min and the 20G is 44lb/min. The AVO380 is 45lb/min which puts it much closer to the 20G realm. With (if the claims pan out) cooler intake temps and faster spool due to the smaller hotside than its big-brother AVO420 (also 45lb/min, but larger hotside). The same day LBGT's car hit 337/322, an 18G Legacy hit 282/262. The meth probably helped in LBGT's case, but still, that's quite a jump. And there's reason to believe he can get more power out of it with fuel upgrades. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted April 16, 2007 Share Posted April 16, 2007 288 on a 18g is just weak. people are running 270-275 with headerback exhaust intake and a tmic. Link to comment Share on other sites More sharing options...
NSFW Posted April 16, 2007 Share Posted April 16, 2007 Naturally, they say the dyno reads low... But the 18G doesn't seem to be worth much more than the plumbing upgrades behind it, as far as I can tell. A little more, yes, but not a lot. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted April 16, 2007 Share Posted April 16, 2007 scans had a 18g fmic, up , tbe and got 326ish whp Link to comment Share on other sites More sharing options...
wukindada Posted April 16, 2007 Share Posted April 16, 2007 Best figures I've been able to collect say the 18G is 39 lb/min and the 20G is 44lb/min. The AVO380 is 45lb/min which puts it much closer to the 20G realm. With (if the claims pan out) cooler intake temps and faster spool due to the smaller hotside than its big-brother AVO420 (also 45lb/min, but larger hotside). The same day LBGT's car hit 337/322, an 18G Legacy hit 282/262. The meth probably helped in LBGT's case, but still, that's quite a jump. And there's reason to believe he can get more power out of it with fuel upgrades. Know this though...the 380 is rated a little larger than the 18G but usually there dyno plots are about the same. The topend going to the 380. Even though the 20g is about the same size it's power levels are higher than what I have seen accomplished with a 380 but a little less than the AVO420. As you mentioned meth tends to give you quite a increase;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
noam Posted April 16, 2007 Share Posted April 16, 2007 Naturally, they say the dyno reads low... But the 18G doesn't seem to be worth much more than the plumbing upgrades behind it, as far as I can tell. A little more, yes, but not a lot. Simply not true... Here is a comparison of a stage2 vs my avo400 setup. This is before the final set of tweaking that took me to 300 whp: http://www.tdctuning.com/dynocharts/vf400.GIF Here is the same comparison on scans007's 18G (although with a different dyno setup so the numbers are scaled differently): http://www.pimpmyauto.com/Legacys/Data/Dyno/18gFMIC.GIF Link to comment Share on other sites More sharing options...
sutter2k Posted April 16, 2007 Share Posted April 16, 2007 Another 18g (mine). Of course I am not making this now since my smc kit needs a new pump. But I'll be back with meth next time instead of denatured and perhaps tgv deletes. Hoping to break 350whp on that dyno. http://sutternow.com/pics/lgt/dynos/8cm_alky.jpg Link to comment Share on other sites More sharing options...
LittleBlueGT Posted April 16, 2007 Share Posted April 16, 2007 Best figures I've been able to collect say the 18G is 39 lb/min and the 20G is 44lb/min. The AVO380 is 45lb/min which puts it much closer to the 20G realm. With (if the claims pan out) cooler intake temps and faster spool due to the smaller hotside than its big-brother AVO420 (also 45lb/min, but larger hotside). The same day LBGT's car hit 337/322, an 18G Legacy hit 282/262. The meth probably helped in LBGT's case, but still, that's quite a jump. And there's reason to believe he can get more power out of it with fuel upgrades. I don't know guys if the 18g had an intake or OEM CBE, I imagine it had minimal mods. Remember though that the GT30 they did only got 350 and the FPG only got 300. The AVO380 will walk away from an 18g, no question. A 20g is a different story as it likely has a less restricitive hotside possibly allowing higher top end numbers, but maybe not either. The AVO380 may be the spool of an 18g and the topend of the 20g. What usually does better, a 20G or an FPG? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
sutter2k Posted April 16, 2007 Share Posted April 16, 2007 re: though that the GT30 they did only got 350 I believe the owner of the GT30 asked for conservative numbers. Link to comment Share on other sites More sharing options...
NSFW Posted April 16, 2007 Share Posted April 16, 2007 Thanks for the dyno charts, guys. I didn't realize the 18G had that much in it. Link to comment Share on other sites More sharing options...
sutter2k Posted April 16, 2007 Share Posted April 16, 2007 ^ Well these are the 18g results from my first trip out there(vs the one above).So after perrin headers, prodrive boost selenoid, full tbe (vs just dp, and perrin y-pipe), 8cm housing, aem intake, smc alcohol kit. And lots not forget, just the fact that the turner gets to spend more time with your car makes a big difference. I think thats a pretty big before/after with basically the same turbo.http://sutternow.com/pics/lgt/dynos/18gdyno1sm.png Link to comment Share on other sites More sharing options...
LittleBlueGT Posted April 16, 2007 Share Posted April 16, 2007 re: though that the GT30 they did only got 350 I believe the owner of the GT30 asked for conservative numbers. I am sure you are right, I still think it shows that PDX's new mustang dyno is a very low reading one. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
