rudy Posted March 13, 2007 Share Posted March 13, 2007 I just dropped ~$195 @ Liberty Subaru (thanks for the deal by the way - discount if you mention the forum) for 4 of these things. Just a heads up to anyone considering two sets of wheels/tires and not wanting to do the black tape mod to disable the dashboard light. I was considering the ContiSportContact 3's, but I think I'm going to save the $200 the TPMS cost me and go with Azeni's. Link to comment Share on other sites More sharing options...
jRS2.5 Posted March 13, 2007 Share Posted March 13, 2007 That's cheap. The Subaru dealer I checked (Longs) wanted $87+ apiece. May have to stop by Liberty!! Link to comment Share on other sites More sharing options...
jRS2.5 Posted March 14, 2007 Share Posted March 14, 2007 Also, I just changed over to 225/45 x 17 on some Rota rims I had for my 2004 STi. I went ahead without adding new TMPS to the older setup. I thought I would have to look at a flashing TMPS error all the time, but it is not really that bad. It normally takes about 50 miles before it flashes the first time, and then it only flashes about once every 10 minutes. I assumed it would be on for the entire time, like the DRL lite. The 17inch tires really make the wheel gap noticeable, but they handle well. I was just deciding whether to sell the 17's and pick up some 18 x 8 or 18 x 8.5 for some larger tire sizes. I will probably pick up a different TMPS system, since they have some that are sensitive to .1 lb of pressure, and also show each wheel and the temp for each wheel. Link to comment Share on other sites More sharing options...
red beast Posted March 15, 2007 Share Posted March 15, 2007 4 for $195 is cheap they charged me $70 each 2 years ago and i've bought four cars from them, mentioned the forums, and promoted them here. Link to comment Share on other sites More sharing options...
axis008 Posted March 15, 2007 Share Posted March 15, 2007 If you buy one set, could you remove it and use it on a different set of wheels later? Probably not huh, or else you guys would have used the ones on your stockers. -ben Link to comment Share on other sites More sharing options...
jRS2.5 Posted March 15, 2007 Share Posted March 15, 2007 You can remove and remount the TMPS sensors from wheel to wheel. If you want two sets of wheels (summer/winter), you need two sets of sensors. Also, when remounting, you may need to have Subaru techs recalibrate the system. The Subaru TMPS system does not show which wheel is low, you have to check them all. There are other systems that show you the pressure in each wheel, the temp in each wheel, and allow up to 8 sensors for each car. Link to comment Share on other sites More sharing options...
LGT Dave Posted March 21, 2007 Share Posted March 21, 2007 Does anyone know the Part Number for these sensors? Link to comment Share on other sites More sharing options...
rudy Posted March 22, 2007 Author Share Posted March 22, 2007 Does anyone know the Part Number for these sensors? According to the packet, 28103AG00A Link to comment Share on other sites More sharing options...
rudy Posted March 22, 2007 Author Share Posted March 22, 2007 Agh, probably returning these. If anyone wants to take them off my hands, let me know. They don't fit the BBS RK's. So, I guess it's running with the light on until I can disable that somehow. Link to comment Share on other sites More sharing options...
LGT Dave Posted March 22, 2007 Share Posted March 22, 2007 Agh, probably returning these. If anyone wants to take them off my hands, let me know. They don't fit the BBS RK's. So, I guess it's running with the light on until I can disable that somehow. PM sent Link to comment Share on other sites More sharing options...
