mcwiggin Posted March 11, 2007 Share Posted March 11, 2007 Ok so this morning my 2005 Legacy 2.5GT needed a jump because of a dead battery. I asked someone who was walking to there car in my apartment parking lot if they would assist me. During the process or the jump they hooked their cables up with the wrong polarity (red to black, black to red). When we attached everything the horn sounded on my car but I was not worried because this had happened before when I had needed my car to be jumped because of the alarm. After about a minute of my car not starting I went out to check the cables and realized the mistake. When the cables were reconnected the correct way nothing happens. I have checked all the fuses and tried disconnecting the battery (as I imagine it must be severely damaged after being in reverse polarity.) Still nothing. No door lights. No radio. No gauges or illumination. When I turn the key nothing happens at all.. no relays click. The 2 things that do work are the hazard lights and horn. But nothing else. Are there fuses somewhere else that I am not finding? Has anyone made this mistake before? Is there an easy fix to get it started so I can at least drive it to dealer? How bad is the damage that I have done? Status Update I had the car towed to the dealer, Apparently its just a fuse somewhere in the ignition system. The guy on the phone called it a Maxi-Fuse. They believe the reason my battery died in the first place had to do with a recalled part. He didn't say what part but I am sure I will find out when I get the car back later today. They just wanted to run some diagnostics to make sure everything in car is okay. In addition they are giving me a new battery. Turns out everything is going to be fixed at no cost. Link to comment Share on other sites More sharing options...
jerami1981 Posted March 11, 2007 Share Posted March 11, 2007 if your hazards work you must still have power. There are fuses under the dashboard down by the hood releaseish and there is another set out in the engine bay, drivers side up towards the windshield give or take. That one is a black plastic box that you just pop the cover off of. those are the only fuse areas i know of. I also assume you have power if your horn is working. If you look in the back of the manual somewhere it as a listing for both fuse panels as to what they do, that should help you narrow down what fuses to look at. Link to comment Share on other sites More sharing options...
motoracer Posted March 11, 2007 Share Posted March 11, 2007 go into the main fusebox in engine compartment and you should see a main fuse (some call it a jumper) it should be 100A w/ clear window and 2 small phillips screws, one on each side, securing it to the fuse box. Link to comment Share on other sites More sharing options...
BOXRPWR Posted March 11, 2007 Share Posted March 11, 2007 I tried Googling "what happens if you reverse cables during jump-starting a battery" nothing specific but I did find several comments about damaging the car's computer (ECU) if the polarity is reversed. so maybe you fried the brain. Link to comment Share on other sites More sharing options...
mcwiggin Posted March 11, 2007 Author Share Posted March 11, 2007 I checked both fuse boxes... I am thinking the issue may lie with the vehicle immobilizer... or possibly there is a fuseable link somewhere in the wiring harness that I don't know about that may be blown. I will keep you guys posted as to what the issue is when I get it solved Link to comment Share on other sites More sharing options...
hogmeat Posted March 12, 2007 Share Posted March 12, 2007 Oh Hogmeat! I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted March 12, 2007 Share Posted March 12, 2007 damn that person pwned you good. Hope its nothing serious. Link to comment Share on other sites More sharing options...
mcwiggin Posted March 12, 2007 Author Share Posted March 12, 2007 The only payback I get for the idiot who put his cables on backward (of course I should have checked to make sure he had them right) is I am sure it did a number on his alternator. When the cables were hooked up his car was struggling to stay running. I just though his car was a piece of crap.. Little did I know it was trying to reverse the polarity on my car. Link to comment Share on other sites More sharing options...
ckrieg Posted March 12, 2007 Share Posted March 12, 2007 crazy, what a dumbass! hahah who can't line up the colours?! Either way, the closets experience that I have to this is hooking up the power and ground on my amp backwards which just tried the 80amp inline fuse everytime. Maybe try a new battery? Did you check the master fuse that motoracer is talking about? Otherwise call your local subaru dealership tomorrow. Good luck!! Link to comment Share on other sites More sharing options...
mcwiggin Posted March 12, 2007 Author Share Posted March 12, 2007 I checked the master fuse its good... I am thinking there is something preventing the more advanced electronics (ECU, DICE, ect...) from being grounded... Is there some other fuse that isn't in either fuse box that could be cutting off power to all the advanced electronics in car. The car is going in for service tomorrow. Link to comment Share on other sites More sharing options...
zmarko Posted March 12, 2007 Share Posted March 12, 2007 several comments about damaging the car's computer (ECU) if the polarity is reversed. so maybe you fried the brain. +1 Link to comment Share on other sites More sharing options...
robinlsb Posted March 12, 2007 Share Posted March 12, 2007 Brain dead:( "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
BMac1203 Posted March 12, 2007 Share Posted March 12, 2007 Brain dead:( My guess... Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
GTTuner Posted March 12, 2007 Share Posted March 12, 2007 Dont forget there are a ton of fuses under the dash. Link to comment Share on other sites More sharing options...
BMac1203 Posted March 12, 2007 Share Posted March 12, 2007 Id assume that he checked them....but maybe not? I wouldve checked EVERY fuse. Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
mcwiggin Posted March 12, 2007 Author Share Posted March 12, 2007 I have checked every fuse. Its being towed in an hour. I am hoping that by just telling the dealer it "died inexplicably" they will do the repairs under warranty. Link to comment Share on other sites More sharing options...
SQC049 Posted March 12, 2007 Share Posted March 12, 2007 I think you killed your ECU Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
BMac1203 Posted March 12, 2007 Share Posted March 12, 2007 Good luck! Update us when you can. Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
jmanzs Posted March 12, 2007 Share Posted March 12, 2007 I think you killed your ECU +1 good luck on figuring it out! Link to comment Share on other sites More sharing options...
lawl Posted March 12, 2007 Share Posted March 12, 2007 On a happier note you have another 100 flashes! car for sale. PM me! Link to comment Share on other sites More sharing options...
DukeTrout Posted March 12, 2007 Share Posted March 12, 2007 Also check under the car in the front. There is a ground line (looks like a clear-coated speaker cable) attached to the engine. If that is disconnected or fried, your electronics can't get a decent ground. Lights and such might work, but not anything that requires a nice, stable baseline ground. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
BMac1203 Posted March 12, 2007 Share Posted March 12, 2007 Surprisingly, Ive heard of that. Not anyone frying that ground (would require a short?) But I have heard of swapped engines not starting due to poor grounds. Check it out! Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted March 12, 2007 Share Posted March 12, 2007 Did the sparks that fly not clue him in???? OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
BMac1203 Posted March 12, 2007 Share Posted March 12, 2007 Hah. Well, surprisingly, Im sure that weve all seen many incorrect jumps in our days. The other guy was probably one of those kids that tried to hammer the square into the circle hole at pre-school. There's a reason that they not only color code the jumper cables....but also put "+" & "-" on most... Need a CarPC bezel? PM me! Link to comment Share on other sites More sharing options...
PeterJMC Posted March 12, 2007 Share Posted March 12, 2007 Maybe next time you can jump start your car like a genius... [ame=http://www.metacafe.com/watch/427774/jump_start_car_like_a_genius/]Jump Start Car Like A Genius Video - Metacafe[/ame] Link to comment Share on other sites More sharing options...
