subaru-man Posted February 18, 2007 Share Posted February 18, 2007 Hello, I have a 2006 2.5L wagon with an Automatic transmission. How can I add more transmission fluid to my car? The transmission fluid appears to be low. Link to comment Share on other sites More sharing options...
PhilT Posted February 18, 2007 Share Posted February 18, 2007 Through the dipstick tube. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
subaru-man Posted February 18, 2007 Author Share Posted February 18, 2007 Does the same applies if one was to replace the transmission fluid? It seems that it would take a long time to refill it. BTW, how much transmission fluid is needed on an Automatic? Thanks in advance. Link to comment Share on other sites More sharing options...
fweasel Posted February 19, 2007 Share Posted February 19, 2007 Does the same applies if one was to replace the transmission fluid? It seems that it would take a long time to refill it. BTW, how much transmission fluid is needed on an Automatic? Thanks in advance. Yes, after a complete drain, you still fill it up from the dipstick tube. A funnel helps and it doesn't take all that long. Not sure how much the auto takes, I have a manual. Should be able to find it quickly with search. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
PhilT Posted February 19, 2007 Share Posted February 19, 2007 9.3 litresVehicle Specifications.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
subaru-man Posted February 19, 2007 Author Share Posted February 19, 2007 Thank you both for the info. Link to comment Share on other sites More sharing options...
c-lo Posted February 19, 2007 Share Posted February 19, 2007 :spin: 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
hogmeat Posted February 19, 2007 Share Posted February 19, 2007 caution: if you don't know where the fluid goes - don't fill it. For your own safety, man. I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
pillboy Posted February 19, 2007 Share Posted February 19, 2007 caution: if you don't know where the fluid goes - don't fill it. For your own safety, man. Hope you follow your own advice with the Hoglet on Saturday nights. It is still ugly. Link to comment Share on other sites More sharing options...
