where to add transmission fluid...
Posted
Does the same applies if one was to replace the transmission fluid? It seems that it would take a long time to refill it.
BTW, how much transmission fluid is needed on an Automatic?
Thanks in advance.
Posted
Thanks in advance.
Yes, after a complete drain, you still fill it up from the dipstick tube. A funnel helps and it doesn't take all that long. Not sure how much the auto takes, I have a manual. Should be able to find it quickly with search.
ignore him, he'll go away.
Posted
:confused::spin: :spin: :spin:
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
Posted
caution: if you don't know where the fluid goes - don't fill it.
For your own safety, man.
Hope you follow your own advice with the Hoglet on Saturday nights.
It is still ugly.
