C.S. Posted February 4, 2007 Share Posted February 4, 2007 Hi, Do the rear Two-Pot Caliper Adapters, like WRX kit http://www.fastwrx.com/retwcaad.html fit in LGT05? http://us.st11.yimg.com/us.st.yimg.com/I/fastwrx_1934_138444678 I'll change my brake kit for Brembo STI V7... I've searched, and I found any comments about Gospeed..... [url=http://www.fastwrx.com/retwcaad.html][/url] Link to comment Share on other sites More sharing options...
praedet Posted February 5, 2007 Share Posted February 5, 2007 Looking into it... Link to comment Share on other sites More sharing options...
praedet Posted February 6, 2007 Share Posted February 6, 2007 I think it will, but I am not 100% sure. Link to comment Share on other sites More sharing options...
edmundu Posted February 6, 2007 Share Posted February 6, 2007 I don't think this would work on Brembo caliper's. they utilize a 20mm rotor, vs 18mm on the std Wrx 2 pot. This would have the caliper moved slightly. Not to mention the diameter difference of almost 1", and aren't the bolt spacing between the 2 pots and Brembo's different? I could be wrong, but I thought there was a thread on exactly this topic over on Nasioc.... Link to comment Share on other sites More sharing options...
biz77 Posted February 7, 2007 Share Posted February 7, 2007 I'm not sure if he is looking to put the FHI two pots on or the Brembos??? The WRX two-pot SHOULD fit based on the popular and relatively easy retrofit of our LGT rear brakes onto other platforms that use the R160 diffs. We already know the Brembos will work - Look here: http://www.fastwrx.com/brstibrup.html Link to comment Share on other sites More sharing options...
praedet Posted February 7, 2007 Share Posted February 7, 2007 I think he is talking about the 06 WRX and up Subaru rear 2-pots. They do not fit as a direct bolt-on to previous years or the LGT. That is why this adapter exists. The Brembo do bolt up with special rotors and bracket... Link to comment Share on other sites More sharing options...
