Pman2g Posted February 2, 2007 Share Posted February 2, 2007 Ok, Ive done research and saw the manual pic how to adjust the headlight height but I cannot find the damn screw to adjust it. Could it be that there is a cap over it? In the spot I think it should be, there is a metal cap like thing that is round with like a bolt head attached. It spins freely so its not threaded in. Do I have to remove this in order to get to the adjusting screw? It was cold and late so I didnt feel like trying to get it off. Thanks for any help. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted February 5, 2007 Share Posted February 5, 2007 it isn't a bolt that threads in or out... it is a bolt head with gear teeth on the other side, and it drives a worm gear, that adjusts the headlight. The bolt may not move in or out, but you are indeed adjusting the headlight. It is a good deal of gear reduction, so a long turn doens't move the headlight all that much, and allows precise aiming. Link to comment Share on other sites More sharing options...
Scooter Posted February 5, 2007 Share Posted February 5, 2007 It's not covered. It's the silver-color 8mm hex head with big flat washer that's just inboard and a little low of the big round caps that cover the bulbs. You'll need a small socket to get in there, as threre's not a whole lot of room to wrench on it. I think it's the only silver bolt head around that area. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 6, 2007 Share Posted February 6, 2007 there is a hidden horizontal adjustment bolt aswell...... I'd take pics but its dark right now OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
mikeyan Posted February 6, 2007 Share Posted February 6, 2007 there is a hidden horizontal adjustment bolt aswell...... I'd take pics but its dark right now when you get a chance man! SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted February 6, 2007 Share Posted February 6, 2007 Cool I need to do this tomarrow If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 6, 2007 Share Posted February 6, 2007 the horizontal adjustment bolts the same size but it has a cover on it so you have to just get a flat head and pop the cover off then adjust. I don't even have my cover's on anymore once I popped them off. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted February 9, 2007 Share Posted February 9, 2007 Hey lets have a head light adjustment meet. You can help me adjust the lights and Doctorchu sit in his car and tell us when the light hit his rearview. If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 9, 2007 Share Posted February 9, 2007 that wouldn't work. You have to take into consideration the road conditions of when the car bumps aswell. If you know of a flat surface with a wall I'd be more then happy to meet up and do alignments. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted February 9, 2007 Share Posted February 9, 2007 cool. they are just lower now cause of the springs If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 9, 2007 Share Posted February 9, 2007 I understand. I've probably aligned my lights like 20+ times by now and I'm still not satisfied so I'm doing it again tonight. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Deepwoods Posted February 15, 2007 Share Posted February 15, 2007 I had the same issure; lower springs = bad headlight orientation (which state safety inspector didn't like...) I did adjust the lights but they need further attention. Can anyone give me a good, general guideline for how high the beam should be. E.g. put an object "x" feet away and have the top cut off approx "y" feet off the ground. Thanks Link to comment Share on other sites More sharing options...
Fat Charlie Posted February 16, 2007 Share Posted February 16, 2007 Laws vary state to state. Checking with an inspection station is a good idea. If the headlight aiming fails inspection, then what is needed to fix it for a sticker? A good rule of thumb for low beams is nothing even approaching horizontal. Pulling a number out of my ass, I think the beam shouldn't hit the ground more than 100 feet away. I'm completely unsure about the distance, but I think the standard is how far away on the ground the beam reaches. If your headlights start out above the height of a trunk, a good rule of thumb is hanging yourself. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 16, 2007 Share Posted February 16, 2007 http://legacygt.com/forums/showthread.php?p=1006329#post1006329 Click there if you need to know how to align your lights. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Deepwoods Posted February 16, 2007 Share Posted February 16, 2007 That's a great link, that I seemed to miss during my search. Thank you. Link to comment Share on other sites More sharing options...
