nendo Posted October 20, 2004 Share Posted October 20, 2004 would my ap racing 4pots on my wrx work on the gt? i still have them sitting in a box and havent tried test fitting them yet. i got them from agroup buy on nasioc board last year, they r quite lightweight and the rotor is the same size as the gt rotor.. they worked pretty well on the wrx and they were small enough that they could be fit under stock 16 wrx wheels, so clearence wouldnt be a problem Link to comment Share on other sites More sharing options...
apexjapan Posted October 20, 2004 Share Posted October 20, 2004 I'm not sure that they'd be direct bolt-up - the Legacy GT has a larger front rotor than the WRX, but smaller than the STi. Brackets are necessary here in Japan, we are working on one ourselves for a caliper w/STi 330mm rotor big brake combination. A pair of brackets shouldn't be too expensive if you do need them, though. Cheers, Paul Hansen [url]www.avoturboworld.com[/url] [url]www.apexjapan.com[/url] Link to comment Share on other sites More sharing options...
Xenonk Posted October 20, 2004 Share Posted October 20, 2004 dont forget thickness too.. unless you have some kind of full AP Racing brake kit that included the rotor, brackets, and caliper with ss lines.. I would say DO IT! and give it a test fit. Keefe Keefe Link to comment Share on other sites More sharing options...
nendo Posted October 20, 2004 Author Share Posted October 20, 2004 yah its a full kis, slotted rotors, bracket, calipers,, gonna prob test fit them within a week Link to comment Share on other sites More sharing options...
Xenonk Posted October 20, 2004 Share Posted October 20, 2004 it's just the front kit right? Well, I know the rear is different in diameters due to the e-brake drum setup.. that's why I am waiting on Endless to finish up with their FULL front and rear kit. Keefe Keefe Link to comment Share on other sites More sharing options...
nendo Posted October 22, 2004 Author Share Posted October 22, 2004 yeah just a front kit,, gonna try to fit it next week,, they arnt huge brakes but they r an improvement, and they r very light, i lost 8 pounds on each side on my wrx Link to comment Share on other sites More sharing options...
Xenonk Posted October 22, 2004 Share Posted October 22, 2004 good luck on the fitment.. let us know how it goes... check for wheel clearance too! Keefe Keefe Link to comment Share on other sites More sharing options...
nendo Posted October 22, 2004 Author Share Posted October 22, 2004 i highly doubt clearance would be an issue as they fit under my wrx with much room to spare... im just worried bout the bracket! prob gonna have to be modified,, yuck Link to comment Share on other sites More sharing options...
Xenonk Posted October 22, 2004 Share Posted October 22, 2004 that's what we are all worried about.. I assume the SSRs have plenty of caliper clearance. Keefe Keefe Link to comment Share on other sites More sharing options...
GTBGUY Posted October 27, 2004 Share Posted October 27, 2004 [b]nendo[/b] - Are you referring to the iON Performance/AP Racing set-up? If so, it should work. Both F&R BBK's would work; you could also run some 16" wheels then! Link to comment Share on other sites More sharing options...
