legacyboy8929 Posted January 26, 2007 Share Posted January 26, 2007 i have a 07 legacy sedan limited ,5EAT is there any difference if i were to use the sportshift or not. Link to comment Share on other sites More sharing options...
Hanger Posted January 26, 2007 Share Posted January 26, 2007 When you shift your knob to the left, on the gauge it shows SPORTSHIFT It basically rev up to red line every gear If you pull down your shift knob, the gauge will show which gear you're in, then you can use the manual shift ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Dong Homez Posted January 26, 2007 Share Posted January 26, 2007 Why don't you use it and answer your own question? Link to comment Share on other sites More sharing options...
legacyboy8929 Posted January 26, 2007 Author Share Posted January 26, 2007 i have but i havent seen a difference that much, some one said it makes u go faster, and others say if you do use it but dont know how to it can ruin the gears or something like that not sure. Link to comment Share on other sites More sharing options...
wukindada Posted January 26, 2007 Share Posted January 26, 2007 As a general rule.... When on the highway I always have the car in "D" when around town "S" Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
one69chev Posted January 26, 2007 Share Posted January 26, 2007 put in sport shift and floor it, then come to a stop put in "d", then floor it again, if u can't feel a fifference, your butt dynomometer might be broken.... welcome to the site, btw..... Link to comment Share on other sites More sharing options...
Dong Homez Posted January 26, 2007 Share Posted January 26, 2007 put in sport shift and floor it, then come to a stop put in "d", then floor it again, if u can't feel a fifference, your butt dynomometer might be broken.... Even though I know there's no difference, I'm gonna take your advise and go floor it. Hahahaha Link to comment Share on other sites More sharing options...
ATCQ110 Posted January 26, 2007 Share Posted January 26, 2007 The only thing that sport shift does is hold the shifts points out longer, and it will not immediately up shift after it down shifts and you let off the throttle. It does not make a difference in the power out put. And You certainly do not have to worry about screwing up your trans by using it "wrong" Link to comment Share on other sites More sharing options...
washmyscooby Posted January 26, 2007 Share Posted January 26, 2007 mine seems to shift a little harder in sport mode.. that might be because its shifting at higher rpms.... I also notice if you let off the gas and the car is in 2nd gear..it stays in that gear and wont shift up to 3rd. Link to comment Share on other sites More sharing options...
