alegacy Posted January 25, 2007 Share Posted January 25, 2007 Ok folks.. for 17k miles I have endured a vibration (similar to unbalanced wheels or bent rim) at 75-80 mph... Nothing before, and it gets even worse above 110. The dealer has rebalanced the wheels, removed the tires, checked the rims for true/bends multiple times. I have had snows and summer tires on and off the rims 2x, and every rim has been on a different corner of the car, several times. The car has been aligned (it initially pulled to the right like everyone else's) So what the heck is it? Drive 3 hours and the vibration through the wheel puts my left hand to sleep.. Anyone else out there with a similar issue? If so, how have you solved it (what was it?) or have you? Thanks for the help. Link to comment Share on other sites More sharing options...
Andyjo Posted January 25, 2007 Share Posted January 25, 2007 Warped Rotor could do that. (and yes, even if you aren't pressing the brake.) Link to comment Share on other sites More sharing options...
Ed_T Posted January 25, 2007 Share Posted January 25, 2007 out of round tire(s) a decent tire shop can test them Link to comment Share on other sites More sharing options...
alegacy Posted January 26, 2007 Author Share Posted January 26, 2007 On the rotor front.. there is no shudder (even minor) under braking. On the tire front, every tire (original and 4 snows) have been on every corner of the car several times by now, 2 tire shops, and 2 dealers have all balanced the wheels/tires multiple times, check for round, and checked rim true.. and report all is well. This is so consistent independant of wheels and tires that I am thinking halfshaft, hub, suspension... anyone out there have and 'odd' experiences? Link to comment Share on other sites More sharing options...
Deer Killer Posted January 26, 2007 Share Posted January 26, 2007 flatspotting is my guess. my flat spots seem to focus around 75mph.. probably some science to that. Park a car with warm tires and get the wheels in the air with some jacks, and leave it overnight. Link to comment Share on other sites More sharing options...
tantal Posted January 26, 2007 Share Posted January 26, 2007 I had a rotor problem with my A4 - I tried the same things as you, but noticed this at different speeds. It turned out that, while I didn't feel like there was any vibration under braking, after the rotors were replaced, I immediately noticed the car was far smoother under braking than before. Bottom line, you may have a rotor problem even though it doesn't seem to vibrate under braking - maybe the frequency of vibration is such that you don't notice it. Or, it could be something else . . . . =\ Link to comment Share on other sites More sharing options...
