Legacy2.5R Posted January 23, 2007 Share Posted January 23, 2007 is there any chemical agent that breaks down fiberglass/bondo? if not are there any suggestions in doing so? Link to comment Share on other sites More sharing options...
evoguy5 Posted January 23, 2007 Share Posted January 23, 2007 what kind of situation are you in, i would recommend cutting of if you have a large excess and then just sanding down the details smooth Link to comment Share on other sites More sharing options...
Scotty Posted January 23, 2007 Share Posted January 23, 2007 There are chemical strippers you can buy that will eat through epoxy, they might go through polyester resin that many people use with fiberglass when they don't use epoxy. Link to comment Share on other sites More sharing options...
072 Posted January 24, 2007 Share Posted January 24, 2007 acetone will break down resin and bondo if either is not fully hardened. be carefull of what else you get acetone on, it will eat that too Link to comment Share on other sites More sharing options...
Legacy2.5R Posted January 26, 2007 Author Share Posted January 26, 2007 im thinking sanding.. its the C-West front lip i put on my car a couple months back...it broke in the winter and im just sick of it causeing problems so i broke the rest off by hand a few days ago...it didnet fit the USDM model just right so it was fiberglass molded...trying to save the bumper tho thanks Link to comment Share on other sites More sharing options...
