canis Posted January 21, 2007 Share Posted January 21, 2007 I'm running Stage 1 93 Oct. on an 05 LGT MT. Lately I've been getting a lot of CELs. Usually it's 0302 (cylinder 2 misfire), but it's also been 0304 a couple times. I've gotten the CELs before (every 400 miles or so), but it seemed to be attributed to the AP when cruising on the highway. Now it happens every 15 miles in town. 1. I switched the real time map to "married stock" to see if it was the car or the Access Port, but the AP still reads "Stage 1 93" ? 2. The car is no longer under warranty (37k), so I'm hesitant to bring it in. Bad injectors seem to be a common problem on the board. Where's a good place to get them and how much are they? If it's relatively cheap and simple, I may just replace all 4 with the "new style" and see if that helps. If not, I'll bring it in and have them do compression. Link to comment Share on other sites More sharing options...
mccorry Posted January 21, 2007 Share Posted January 21, 2007 1. A real time map switch will not show up on the AP. It will only show the current base map loaded on the ECU. If you flashed a married stock reatime to the ecu... it's there... even if the AP doesn't show it. 2. I can't help you there.... either a plug, coil, injector, or compression issue. Link to comment Share on other sites More sharing options...
meier motor sports Posted January 21, 2007 Share Posted January 21, 2007 swap suspected parts and see if the problem follows Link to comment Share on other sites More sharing options...
canis Posted January 26, 2007 Author Share Posted January 26, 2007 My most recent CEL was 0301 and 0304. I can't really swap parts, because I've gotten codes for all four cylinders. There is no noticeable difference in the way the car handles. It's got a very slight shudder at idle (attributed to the boxer design), but otherwise seems to run normally. Could my spark plugs be bad at 37k? I had AutoZone pull the codes to see if they could provide any additional info, but they just told me cylinder misfire, which I already knew. What should be my next course of action: 1) new plugs; 2) new injectors, or; 3)bring it to the dealer? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 26, 2007 Share Posted January 26, 2007 I thought powertrain warranty was > 36000 miles? Did you check the coils? Link to comment Share on other sites More sharing options...
RabidMonk Posted January 26, 2007 Share Posted January 26, 2007 If the code is only one or two cylinders, check coils, injectors, and plugs. If you are intermittently getting codes for all four cylinders, it is unlikely to be four bad injectors or coils. In that case check plugs and look for a possible boost leak. Link to comment Share on other sites More sharing options...
mccorry Posted January 26, 2007 Share Posted January 26, 2007 ^^^^^^^^^^^^^^ I would argue that misfires in 2 or more cylinders is not coils or injectors. It would be one hell of a coincidence for two injectors or coils to die at once... Link to comment Share on other sites More sharing options...
meier motor sports Posted January 27, 2007 Share Posted January 27, 2007 how bout 1 coil & 1 injector? lol Link to comment Share on other sites More sharing options...
NewScooby Posted January 27, 2007 Share Posted January 27, 2007 The car is no longer under warranty (37k) Would this not be covered under the 5/60,000 powertrain? I would unmarry the Accessport and drive it to the dealer and ask them to fix it. Link to comment Share on other sites More sharing options...
KTM 525 Posted January 27, 2007 Share Posted January 27, 2007 Would this not be covered under the 5/60,000 powertrain? I would unmarry the Accessport and drive it to the dealer and ask them to fix it. Oh boy now you've done it wait till the do gooders hammer you for this one....... Link to comment Share on other sites More sharing options...
meier motor sports Posted January 27, 2007 Share Posted January 27, 2007 what if u unmarry the ap and all problems go away? then what? Link to comment Share on other sites More sharing options...
sutter2k Posted January 28, 2007 Share Posted January 28, 2007 I have been having miss fires since Dec when it started getting cold. Not sure if its the plugs, or the injectors are too big to have a clean idle when cold. Or hopefully I don't have a more expensive issue(fingers crossed). With this, my ticket, a miss behaving SMC alcohol pump, and scare about KW coilovers breaking. Having a modified car has not been fun lately. Link to comment Share on other sites More sharing options...
canis Posted January 29, 2007 Author Share Posted January 29, 2007 The whole code throwing thing has been more frequent since it's gotten cold. I didn't realize powertrain was 5yr/60k - that would be great. I've been running the "married stock" map for some time now, and have still gotten codes. What would be the difference with this and unmarrying that would potentially cause the problems? If the powertrain is still under warranty, I'll bring it in and see what they say. Link to comment Share on other sites More sharing options...
ilh Posted January 29, 2007 Share Posted January 29, 2007 I wonder if it could even be covered by the longer federal emissions warranty. If it is throwing codes related to misfiring, that must mean increased emissions. Link to comment Share on other sites More sharing options...
