subiesales05gt Posted January 20, 2007 Share Posted January 20, 2007 2005 legacy gt,losing power at and above 3500 rpm. scanned with moniter and noticed the misfire moniter for cylinder #2 goes to the max. installed a new injector,but no change. swapped the coil from cyl #2,to #4,and still no change. tested the compression,and it is normal at 140 psi when cold. monitered fuel pressure,and it is at 40 psi. car has has the software upgade performed at the dealer for the stumble issue as well.any suggestions? Link to comment Share on other sites More sharing options...
edmundu Posted January 20, 2007 Share Posted January 20, 2007 Have you datalogged the car? Link to comment Share on other sites More sharing options...
subiesales05gt Posted January 20, 2007 Author Share Posted January 20, 2007 yeah we did. the egt sensor went up to 1160 deg. Link to comment Share on other sites More sharing options...
robinlsb Posted January 20, 2007 Share Posted January 20, 2007 2005 legacy gt,losing power at and above 3500 rpm. scanned with moniter and noticed the misfire moniter for cylinder #2 goes to the max. installed a new injector,but no change. swapped the coil from cyl #2,to #4,and still no change. tested the compression,and it is normal at 140 psi when cold. monitered fuel pressure,and it is at 40 psi. car has has the software upgade performed at the dealer for the stumble issue as well.any suggestions? Spark plug?????? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
subiesales05gt Posted January 21, 2007 Author Share Posted January 21, 2007 yeah we checked that too. Link to comment Share on other sites More sharing options...
Jon in CT Posted January 21, 2007 Share Posted January 21, 2007 subiesales05gt, I need some translation from Canadian to US. When you wrote "scanned with moniter" did you mean scanned with a Subaru Select Monitor? When you wrote "the misfire moniter for cylinder #2 goes to the max" did you mean Roughness Monitor #2 goes to the max? When you wrote "the egt sensor went up to 1160 deg" did you mean the factory EGT sensor reported 1160°C (2120°F)? Has the ECM set a P0302 trouble code yet? If so, was the MIL flashing? Link to comment Share on other sites More sharing options...
subiesales05gt Posted January 22, 2007 Author Share Posted January 22, 2007 i will get the mechanic to chime in here. he will be able to answer those questions. thanks Link to comment Share on other sites More sharing options...
subiesales05gt Posted January 24, 2007 Author Share Posted January 24, 2007 yeah we used the select monitor 3 and it was the roughness monitor and the temp was 1160 celsius. yes we did get that code and the mil flashed. we also got three other codes. p1301 , p1544, p0545. Link to comment Share on other sites More sharing options...
