sirsimon Posted January 19, 2007 Share Posted January 19, 2007 Hello suspension and brake gurus! I am getting my pink springs installed next Monday. In reading through a spring install walkthrough, I noticed that it is necessary (at least in front) to pull the brake lines. I will not be doing the work, but I have a quick question for you: Since I may want to go to SS brakelines at some point (just to improve pedal "feel"), would I likely save on labor by having this done at the same time as the spring installation? Thanks in advance for your advice! Link to comment Share on other sites More sharing options...
bmorrisj Posted January 19, 2007 Share Posted January 19, 2007 the brake lines arent pulled, its just a couple of line routing brackets, little clip things.. Link to comment Share on other sites More sharing options...
froggert Posted January 19, 2007 Share Posted January 19, 2007 the wheels will be off and the car will already be in the air. Link to comment Share on other sites More sharing options...
wukindada Posted January 19, 2007 Share Posted January 19, 2007 If this is being done @ a shop I would say go ahead & do the lines also....make sure you get a performance brake fluid:) As Frog mentioned the wheels are already off the car.... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
sirsimon Posted January 19, 2007 Author Share Posted January 19, 2007 Thanks for the help guys! I'll see if it fits into the "budget"! Link to comment Share on other sites More sharing options...
bmorrisj Posted January 19, 2007 Share Posted January 19, 2007 If this is being done @ a shop I would say go ahead & do the lines also....make sure you get a performance brake fluid:) As Frog mentioned the wheels are already off the car.... well yea do the lines now in one shot... Link to comment Share on other sites More sharing options...
drdave39 Posted January 20, 2007 Share Posted January 20, 2007 I had my SS lines (and new Hawk pads and Motul fluid) all installed when I had my Bilsteins installed- added about 1.5 hours of labor- very reasonable (and VERY worth it!) Dave Link to comment Share on other sites More sharing options...
