Bdubs Posted January 16, 2007 Share Posted January 16, 2007 The title says it all, I'm too lazy to look at the back of my 95 stereo to see if this would work, but anyone put a 6disc changer from an 04 WRX in a 95 Leg. or later? I recall seeing somewhere this would work. My stock player and tuner is on the fritz, wondering if this would be worth it. http://forums.nasioc.com/forums/showthread.php?t=1176051 Link to comment Share on other sites More sharing options...
rougeben83 Posted January 16, 2007 Share Posted January 16, 2007 That looks like a double DIN unit. You'll loose one of the cubby holes that is under your current headunit. Otherwise it should fit. I'm not sure about the wiring though; it may be different. Just need a way to connect the pins from that stereo to your harness and you're done. Link to comment Share on other sites More sharing options...
Bdubs Posted January 16, 2007 Author Share Posted January 16, 2007 I already have double DIN, I have the LSi, has the CD player. Was just curious if the pin adapter is the same. Link to comment Share on other sites More sharing options...
SLegacy99 Posted January 18, 2007 Share Posted January 18, 2007 I highly doubt that they would be different. Link to comment Share on other sites More sharing options...
