Guest Posted January 15, 2007 Share Posted January 15, 2007 You can't match front stock springs to Bilsteins or for that mattery any aftermarket struts. You need JDM/Biltein specific springs. Link to comment Share on other sites More sharing options...
robinlsb Posted January 15, 2007 Share Posted January 15, 2007 You can't match front stock springs to Bilsteins or for that mattery any aftermarket struts. You need JDM/Biltein specific springs. I do not think the above is true!!! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Guest Posted January 15, 2007 Share Posted January 15, 2007 I do not think the above is true!!! I do not only think so, but I am 100% sure, unless new struts appear that work with with stock USDM top hats and springs. Link to comment Share on other sites More sharing options...
Vimy101 Posted January 15, 2007 Share Posted January 15, 2007 pork rinds Link to comment Share on other sites More sharing options...
EL PAALO Posted January 15, 2007 Share Posted January 15, 2007 245's and a rear bar. Link to comment Share on other sites More sharing options...
robinlsb Posted January 16, 2007 Share Posted January 16, 2007 I do not only think so, but I am 100% sure, unless new struts appear that work with with stock USDM top hats and springs. Oh, I thought you meant you HAD to change springs! Bilsteins will fit if you use SpecB top hats (although you raise the front slightly) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2007 Share Posted January 16, 2007 Oh, I thought you meant you HAD to change springs! Bilsteins will fit if you use SpecB top hats (although you raise the front slightly) Stock USDM LGT (non-SpecB) springs WILL NOT work with Bilsteins. It's not about top hats, it's about the spring perch located lower on stock KYB vs. Bilsteins. Ergo, longer spring. Even if it fits (if you cram it there), it's not a good idea, since the spring will be seriously mismatched to the strut. Link to comment Share on other sites More sharing options...
robinlsb Posted January 16, 2007 Share Posted January 16, 2007 Stock USDM LGT (non-SpecB) springs WILL NOT work with Bilsteins. It's not about top hats, it's about the spring perch located lower on stock KYB vs. Bilsteins. Ergo, longer spring. Even if it fits (if you cram it there), it's not a good idea, since the spring will be seriously mismatched to the strut. Ok, Unclemat, you have convinced me. Your description would explain the "slight increase" in ride hight. SighHHHHHHHHHHHH---- Iguess I am stuck for now, since I do not want to lower my wagon. So I have just joined the Unclemat's band wagon, NOBODY makes a better shock system for the LGT and you CANNOT upgrade shocks without upgrading springs. There I said it, and I stand corrected!!!! BTW, thanks for saving me big bucks!!!!! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2007 Share Posted January 16, 2007 Don't panic. You can use JDM OEM springs that fit Bilsteins and other JDM sturts perfectly and retain stock height. You will find a set in classifieds right now... Link to comment Share on other sites More sharing options...
OhBe1 Posted January 16, 2007 Share Posted January 16, 2007 to be technically correct, that only happens when you OVER DRIVE the car.. Easy to do with the low limits as delivered, partially due to the wimpy rear sway bar... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
robinlsb Posted January 16, 2007 Share Posted January 16, 2007 Don't panic. You can use JDM OEM springs that fit Bilsteins and other JDM sturts perfectly and retain stock height. You will find a set in classifieds right now... Thanks, but I will wait for the shocks. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
