2006Specb122 Posted December 14, 2006 Share Posted December 14, 2006 I've tried searching for a while and I can't find the answer. I'm hoping someone can help. What is the OEM rear sway bar diameter for 2006 Legacy GT? What is the OEM rear sway bar diamter for 2006 Spec b? What is the OEM rear sway bar diameter for 2007 Legacy GT? I recently read that the 2007 spec b rear sway bar is 15mm in diamter. I am curious how that compares to other legacies. Thanks Link to comment Share on other sites More sharing options...
Scooter Posted December 14, 2006 Share Posted December 14, 2006 As far as I know, they are all the same, at 17mm, I believe. But I'll defer to someone wiser (shouldn't be hard to find!) Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Spec B Posted December 17, 2006 Share Posted December 17, 2006 The GT and the Spec have a 16mm rear sway. I recently swapped the rear out for a JDM rear sway (20 mm); great cheep mod, bolts on in like 30 minutes, no squeaks or rubbing and the car rotates much better. Link to comment Share on other sites More sharing options...
OhBe1 Posted December 19, 2006 Share Posted December 19, 2006 Just for giggles, what's the front diameter? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Spec B Posted December 20, 2006 Share Posted December 20, 2006 No se...I think it is 20mm. Link to comment Share on other sites More sharing options...
rallysquirrel Posted December 21, 2006 Share Posted December 21, 2006 The SpecB rear is definitely 15mm.... ....as I catch my breath from running from the garage after checking. Front looks to be 20mm. I compared it with the aftermarket and didn't seem to be any different. Didn't ACTUALLY check cause I don't have a 20mm wrench to put around it. Link to comment Share on other sites More sharing options...
OhBe1 Posted December 21, 2006 Share Posted December 21, 2006 Funny... Our ('06 LOBW, NA, MT) front is 22. Rear was 15. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Spec B Posted December 21, 2006 Share Posted December 21, 2006 The SpecB rear is definitely 15mm.... ....as I catch my breath from running from the garage after checking. Front looks to be 20mm. I compared it with the aftermarket and didn't seem to be any different. Didn't ACTUALLY check cause I don't have a 20mm wrench to put around it. Did they go to a smaller RSB with the 2007's?? I am very sure that the 05-06 models had 16mm RSB; and only the outbacks & 2.5I's had 15mm. Link to comment Share on other sites More sharing options...
edkwon Posted March 26, 2007 Share Posted March 26, 2007 what is the stock size of the 2.5i front and rear sways? Ed Link to comment Share on other sites More sharing options...
HansGT Posted March 29, 2007 Share Posted March 29, 2007 FWIW....'05 USDM GT 16mm. When I took my rear bar off it was marked "16". Link to comment Share on other sites More sharing options...
Faudi Posted March 29, 2007 Share Posted March 29, 2007 Rear Sway bar 05-07 GT - 16mm 06-07Spec B-15mm 05-07 2.5i-15mm 05-07 H-6-15mm Link to comment Share on other sites More sharing options...
