Silverstar Posted December 19, 2006 Author Share Posted December 19, 2006 I just received my clutch kit, but found that I don't have the ACT pilot bearing. The car is already at the shop with the tranny out, so I'll need a bearing quick before the trans is ready to go back in. Does anyone know if I need the ACT bearing? Can I just use a stock 2.5RS bearing? Thanks! Link to comment Share on other sites More sharing options...
whitetiger Posted December 19, 2006 Share Posted December 19, 2006 use the lgt bearing. if you get a 2.5rs beaing, you have to use a diffent fork. your stock bearing will fit Link to comment Share on other sites More sharing options...
Silverstar Posted December 19, 2006 Author Share Posted December 19, 2006 use the lgt bearing. if you get a 2.5rs beaing, you have to use a diffent fork. your stock bearing will fit I think you mean the throw out bearing, I planned on using the stocker. I don't think the stock pilot bearing will work with the ACT flywheel... Link to comment Share on other sites More sharing options...
whitetiger Posted December 19, 2006 Share Posted December 19, 2006 yeah thats what i meant. i bet the 2.5rs pilot bearing is identical to the lgt bearing. after all the clutch alignment too is the same shape as the 2.5 rs pilot bearing and they are supposed to fit in to the pilot bearing. Link to comment Share on other sites More sharing options...
PhilT Posted December 19, 2006 Share Posted December 19, 2006 yeah thats what i meant. i bet the 2.5rs pilot bearing is identical to the lgt bearing. after all the clutch alignment too is the same shape as the 2.5 rs pilot bearing and they are supposed to fit in to the pilot bearing. It's the same part. The dealer looked up the part # for me, looks like all Subarus since around '98 or maybe before, have the same pilot bearing. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rodan Posted December 20, 2006 Share Posted December 20, 2006 I don't believe the LGT pilot bearing is the same as the RS bearing. You DO want an RS bearing for the ACT flywheel. I went through this when I had my clutch installed. Due to a part being mislabeled, the pilot bearing I got with the kit did not fit. On a hunch, I tried a '99 RS 2.5 pilot bearing the dealer happened to have in stock and it worked. The stock LGT bearing would NOT have worked with the ACT flywheel... Link to comment Share on other sites More sharing options...
