Steering Wheel Extender?
JBLU24
http://www.rotora.com/cgi-local/SoftCart.exe/online-store/scstore/shophome.html?E+scstore
supposedly this will work on any momo or sparco steering wheel
this may be an option for some of us that feel the steering wheel is too far away....
thoughts?
edit- just realized it takes u to the home page....but click on products, then steering wheel extender...
no, that's meant for aftermarket wheels that mount with a different system (allen bolts). Same as a quick release.
the LGT's MOMO wheel fits on a splined hub axle with a 17mm nut to tighten it down. you could put washers underneath the wheel to move it off the base, but do so at your own risk - no idea if it's safe or not (there's almost an inch of overlap)
Bummer. I was just lamenting the distant steering wheel in another thread. I'd need an inch of washers to put the wheel where I want it... leaving zero overlap. :)
On a related note, are there any aftermarket wheels that have airbags? That might be a way to bring the wheel closer, but IMO it's not worth losing the airbag over this.
  • 5 years later...
