skiibumm Posted December 10, 2006 Share Posted December 10, 2006 my highbeams turn on automatically, they are xenons. i had the same kit in my truck and didn't have a problem at all. i've played around with the wiring and still no luck they still turn on. can subarus wiring handle xenons? they should since xenons only put out 35w Link to comment Share on other sites More sharing options...
bmorrisj Posted December 11, 2006 Share Posted December 11, 2006 how did you wire them up.... did you happen to wire them up with headlights and didnt disable the daytime running lights? Link to comment Share on other sites More sharing options...
skiibumm Posted December 11, 2006 Author Share Posted December 11, 2006 daytimes are disabeled, they have been fine for months. but it happens now more then it did before. Link to comment Share on other sites More sharing options...
mr_luv Posted December 11, 2006 Share Posted December 11, 2006 if u have hid's in ur high beams the dash light will be on but not the highs unless u fire them Mr.350 Link to comment Share on other sites More sharing options...
Spec B Posted December 11, 2006 Share Posted December 11, 2006 So you have HID high beams? Or you have HID's and the highbeams (non HID) turn on sporadically? Link to comment Share on other sites More sharing options...
skiibumm Posted December 12, 2006 Author Share Posted December 12, 2006 hids for highs, but they turn on. if i turn on the fogs the highs come on too. something is screwed up. Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 17, 2006 Share Posted December 17, 2006 greg? skibumm? Link to comment Share on other sites More sharing options...
skiibumm Posted December 19, 2006 Author Share Posted December 19, 2006 no, i live in salt lake. the highbeams are just bulbs no projector or reflector. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted January 3, 2007 Share Posted January 3, 2007 High beams definitely have a reflector. Not a parabolic one, and not a projector inversion lens. D2S bulbs are intended for projector housings D2R bulbs are intended for reflector housings, like the 04-05 STI low beam, or other HIDS that use a wide reflector, and no glass hemispherical lens in front of it. Link to comment Share on other sites More sharing options...
