kaho8930 Posted November 23, 2006 Share Posted November 23, 2006 yesterday i saw on ebay a set of 4 caliper of sti and discs for only 305 $ ( front and back ) and i know the bolt pattern of LGT is 5x100 and is it normal that the STI is 5x114.3 original ??? If yes ..what kind of disc i have to use if i put brembo of sti ??? Link to comment Share on other sites More sharing options...
rougeben83 Posted November 27, 2006 Share Posted November 27, 2006 05+ STi's switched over to 5x 114.3 hubs and brake components. AFAIK, you can't use the brake calipers from these as they need the hubs as well. 04 STi's still used the 5x100 hubs and will fit just fine (100% on the front, I think the rear may need the hubs as well, or an adapter as it uses a different hub/rear diff) Link to comment Share on other sites More sharing options...
mwiener2 Posted November 27, 2006 Share Posted November 27, 2006 i super highly doubt someone is selling brembos off an sti, especially calipers, rotors, pads, for 300 something usually just the fronts go for $800 min buyer beware My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
kaho8930 Posted November 28, 2006 Author Share Posted November 28, 2006 i super highly doubt someone is selling brembos off an sti, especially calipers, rotors, pads, for 300 something usually just the fronts go for $800 min buyer beware after the auction , those kit cost 1250$ us but anyways i just change the brake pad today so i wait till it finish then check again from ebay ..... i like the brembo caliper because they cost lot lot cheaper compare as AP , STOPTECH or ENDLESS ( i know they are different but still ....) Link to comment Share on other sites More sharing options...
