mpetty Posted November 15, 2006 Share Posted November 15, 2006 Anyone done this? I have a used STi uppipe I am going to put on in a month or two, and I thought about polishing the inside in the meantime to maximize flow. Two questions, though: 1. Is there any point to doing this? 2. How? What would I use? Jus' wondering. Thanks, Morgan Link to comment Share on other sites More sharing options...
edmundu Posted November 16, 2006 Share Posted November 16, 2006 It is a steel pipe, with welded flanges, and a flex coupling. What are you going to port/polish? If you are going to P&P anything, it should be the cast iron exhaust manifold's. To do that, you'll need an air grinder, as a dremel is just to weak. You pretty much want to gasket match the openings, and where possible to reach in as far as you can to smooth out the interior walls. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted November 16, 2006 Share Posted November 16, 2006 1. No 2. It'd have to be a really long flexible rotary attachement. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
