wrxlvr Posted November 15, 2006 Share Posted November 15, 2006 How difficult is it? Hard to get lined back up? I may be doing a trunk swap this afternoon and want to know what I'm getting into. Link to comment Share on other sites More sharing options...
wrxlvr Posted November 15, 2006 Author Share Posted November 15, 2006 Help? Link to comment Share on other sites More sharing options...
one69chev Posted November 15, 2006 Share Posted November 15, 2006 are you talking about a lid swap? the easiest way to to that is to bolt the new lid on finger tight and SLOWLY close the lid, checking for clearence around the perimeter. are the bolt holes elongated for adjustment on subies? i've never taken my lid off, but all of my chevy's were............. Link to comment Share on other sites More sharing options...
wrxlvr Posted November 15, 2006 Author Share Posted November 15, 2006 Looks like there is the trunk cable and wiring. I'm wondering if just the lid gets swapped, or if the arms do too. And where to disconnect the wiring and release cable. Link to comment Share on other sites More sharing options...
wrxlvr Posted November 16, 2006 Author Share Posted November 16, 2006 So, has no one done this? I took a look at it and could use some help. Link to comment Share on other sites More sharing options...
PhilT Posted November 16, 2006 Share Posted November 16, 2006 You want to swap trunks with someone ?                                            looked to real Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
PeterJMC Posted November 16, 2006 Share Posted November 16, 2006 I've done the trunk lid swap. Removal: Remove the carpet from underneath the trunk lid. Unbolt the trunk at the arms, not the arms from your deck lid. Undo the wiring harness, you may have to cut it free from the plastic pop-its.  When you re-install don't tighten the bolts all the way, you will still need to line up the trunk. Make sure it's lined up correctly before you tighten all the bolts down. It's not too hard, shouldn't take you more than 45 minutes from start to clean-up. The hardest part is trying to line-up the trunk. When I did my trunk swap mine lined up by itself as soon as I bolted everything down. The other guy... it took us a good 15 minutes with someone laying down in the trunk with tools to tighten down the bolts with the trunk closed. We stood outside moving the trunk around and told him to tighten it down when we were all set. Link to comment Share on other sites More sharing options...
wrxlvr Posted November 16, 2006 Author Share Posted November 16, 2006 It looks like the arms' bolts are only accessible from above. Did you have to access the bolts from inside the cockpit (behind the rear seat on the rear deck)? Also, where did you remove the trunk release cable? Link to comment Share on other sites More sharing options...
wukindada Posted November 16, 2006 Share Posted November 16, 2006 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
godwhomismike Posted November 17, 2006 Share Posted November 17, 2006 bwahahahahahahahahahahahahahahahaha Lol@the elephant trunk Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted November 17, 2006 Share Posted November 17, 2006 :lol: :lol: OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
