dannyboy7 Posted November 11, 2006 Share Posted November 11, 2006 So, I have had the Mchulloch 6500k HID kit on for about 3-4 months now, and love the kit, except for one thing. Every now and then, the drivers side will just go out, and when you turn the lights off and then back on again, it comes on and stays on. I have tried wiggling wires around on the ballasts and the light itself, but nothin goes out. Has anyone else had this problem? Link to comment Share on other sites More sharing options...
Yebbey Posted November 11, 2006 Share Posted November 11, 2006 I have the banzaii express kit and get the same problem with the driver's side....I sometimes have to turn it off and on again more than once, but it never goes out once it's back on. Link to comment Share on other sites More sharing options...
VXCL Posted November 11, 2006 Share Posted November 11, 2006 i would just swap the ballasts, ignitors (if sep), and bulbs. obviously only one at a time and see what happens. however i doubt it will solve your problem. i would power the ballasts directly off the batt and ground to the chassis then use a relay triggered by the oem low beam + to power then up. you can find a wire diagram on how to do this in the link in my sig, but you must go to the first page. this will also allow you to retain DRL functionalitly with your xenons. now i have to say it... I HATE KITS!!!! MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
The B4 Posted November 13, 2006 Share Posted November 13, 2006 check your relay coupler. one of your switches may have been pulled loose. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
