ercdvs Posted November 7, 2006 Share Posted November 7, 2006 Just got them on, and the tech put it at 34 (So I was told) I did notice some ever so slight slopping of the tires on a turn as they drove it out of the bay .... but i took it easy on the way home to get a feel for them No pulls, no vibration, noise seems acceptable. I am thinking about topping them all off at 38psi before my 75mph / 20 mi commute in the early am ... what has been a god pressure on these tires? I also have a JDM spec rear sway (20mm) Link to comment Share on other sites More sharing options...
tytek Posted November 7, 2006 Share Posted November 7, 2006 what size? i have 225/45/17 P Zero Nero and run those at +2PSI over stock for street use and +5PSI over stock for track use... oh, and your avatar scares the bejesus out of me everytime i see it - change it, now! Link to comment Share on other sites More sharing options...
ercdvs Posted November 7, 2006 Author Share Posted November 7, 2006 lol ... that avatar was just a temp one I was using .. I never got around to changing it... 225/45/17 is what I ended up with Edit : after checking my tires at the local gas startion with air < 1 mile away, it seems all my tires were at 30psi. I filled up to 38psi all around .. but I think i have a 'bouncy' feel to the tires.. I might drop back to the reccomended 34/36 My review will be up shortly, but so far I am liking these new shoes. Link to comment Share on other sites More sharing options...
TSiWRX Posted November 7, 2006 Share Posted November 7, 2006 What kind of Falkens? My winter setup is the 225/45/17 - the Reinforced version - ZIEX ZE-512s on stock rims. I favor running 38/36 PSI, f/r, cold. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
ercdvs Posted November 7, 2006 Author Share Posted November 7, 2006 we have the exact tire then .. I will probably lower the psi a tad due to the bouncyness i feel ... grr... the day after i get them, there is a rebate out there for them... Link to comment Share on other sites More sharing options...
rougeben83 Posted November 7, 2006 Share Posted November 7, 2006 You may have to run higher psi than other tires of the same size; I've heard from people using Falken's that they use a softer sidewall so you'll need to bump up the air pressure. Link to comment Share on other sites More sharing options...
motoracer Posted November 7, 2006 Share Posted November 7, 2006 running 36/34 (F/R) on OEM tires 40/38 on 18" yokohama paradas 38/36 on 17" bridgestone so-3 Link to comment Share on other sites More sharing options...
