BIU Posted November 9, 2006 Share Posted November 9, 2006 Mr_luv why'd you ditch the RX330 setup for sth else? Link to comment Share on other sites More sharing options...
VXCL Posted November 9, 2006 Share Posted November 9, 2006 Mike add me to the list and I just noticed we have the same projectors hella's right? yeah im running hella units and hella gen 4 ballasts. however i would probably take the tsx over the units i have becuase the cutoff is a step design vs. a slope. that really cuts down on a lot of light forcing you to aim higher. step cut offs are much better. but not worth taking everything apart for minor upgrade. i will totally add you but i have no thread with pics to link to your name. people want the pics and info!!!!!!! MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 Ohhh yeaaaa pix i always forget those hahahahaha yeah im running hella units and hella gen 4 ballasts. however i would probably take the tsx over the units i have becuase the cutoff is a slope design vs. a step. that really cuts down on a lot of light forcing you to aim higher. step cut offs are much better. but not worth taking everything apart for minor upgrade. i will totally add you but i have no thread with pics to link to your name. people want the pics and info!!!!!!! Mr.350 Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 Im still running the Lex units, the 1st retro I did to my leggy was the same as VXCL's. Mr_luv why'd you ditch the RX330 setup for sth else? Mr.350 Link to comment Share on other sites More sharing options...
BIU Posted November 9, 2006 Share Posted November 9, 2006 Im still running the Lex units, the 1st retro I did to my leggy was the same as VXCL's. so are you running the full RX330 setup or are you running the OEM leggy shield/lense combo? How do you like it? Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 OEM leggy shield/lense combo? i like it nice color output combo sharp cut off Mr.350 Link to comment Share on other sites More sharing options...
BIU Posted November 9, 2006 Share Posted November 9, 2006 OEM leggy shield/lense combo? i like it nice color output combo sharp cut off So if i retain the use of the OEM leggy shield/lense combo, i just take apart headlights, remove OEM leggy silver cone and replace with RX330 silver cone and install HID? Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 yea thats it exactly be sure to close the squrell finder you will see it when you get in there cuts down on glare. Mr.350 Link to comment Share on other sites More sharing options...
BIU Posted November 9, 2006 Share Posted November 9, 2006 yea thats it exactly be sure to close the squrell finder you will see it when you get in there cuts down on glare. Hello? come again? You lost me there.. So you would recommend the OEM leggy shield/lense combo over the full RX330 combo? works better? Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 I dont know how the RX set up looks I went straight to the leggy/rx set up Mr.350 Link to comment Share on other sites More sharing options...
BIU Posted November 9, 2006 Share Posted November 9, 2006 thanks for all your help Mr_luv..... Im just in the process of quoting prices and sourcing my parts.... i will join the retrofit club one day! Link to comment Share on other sites More sharing options...
laz Posted November 9, 2006 Share Posted November 9, 2006 I have one question. I already have an aftermarket HID set (XTEC), can I use my existing ballasts and h7 bulbs and just change the projector/mod the shield? Or do I have to buy D2S bulbs? Thanks, X --- Link to comment Share on other sites More sharing options...
mr_luv Posted November 9, 2006 Share Posted November 9, 2006 well you would have to rebase the H7 bulb meaning that little tab on the base of the bulb that goes into the OEM projector slot, but it is possible to the H7 bulb into a D2S housing with a little triming. Mr.350 Link to comment Share on other sites More sharing options...
