Scooby2.5 Posted October 28, 2006 Share Posted October 28, 2006 can anyone here post a step by step process to log using the ECUexplorer so I can send my map logs to TDC. I did a search and saw a long thread but it seemed that it was for a different TARI software than the newer ECUexplorer. Link to comment Share on other sites More sharing options...
rc0032 Posted October 28, 2006 Share Posted October 28, 2006 http://legacygt.com/forums/showthread.php?p=318366#post318366 This should be a start Link to comment Share on other sites More sharing options...
2005garnetGT Posted October 28, 2006 Share Posted October 28, 2006 make sure to use ecuexplorer and not DL1 like the first post says, its a newer and more capable version. Link to comment Share on other sites More sharing options...
noam Posted October 28, 2006 Share Posted October 28, 2006 Here are some instructions straight from TDC... http://www.tdctuning.com/index.php?page=logs Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 29, 2006 Author Share Posted October 29, 2006 Thanks for the replies, But how do you start the logging? I thought there was some way to start by setting up the software to use some switch on the car. Link to comment Share on other sites More sharing options...
KTM 525 Posted October 29, 2006 Share Posted October 29, 2006 I believe if you right click on the top pane it will give you the logging options. Mine is set to log off the rear defog switch. Link to comment Share on other sites More sharing options...
noam Posted October 29, 2006 Share Posted October 29, 2006 If you set it to log the rear defogger switch, then it will auto-start logging when you push it (and stop when you turn it off). Link to comment Share on other sites More sharing options...
yamie700 Posted December 23, 2006 Share Posted December 23, 2006 How do you get ecuExplorer to recognize the car? I have a version 2.0 AP and the usb cable with the little plug/box to connect to OBDII. I plug the OBDII/ usb cord into my laptop with ecuExplorer running but nothing happens. In ecuExplorer on the upper left box it still says ECU (disconnected). I saw on the TDC page where they say to activate FF5OBO and Manifold Relative Pressure and I do have those set to active under User Defined Data Items. How do I make it recognize that it is plugged in to the ECU?? Link to comment Share on other sites More sharing options...
bmorrisj Posted December 23, 2006 Share Posted December 23, 2006 do you have the driver installed for the cable.... on the bottom left pane there is listed available com ports, right clight the correct one for the cable and check SSM communications... Link to comment Share on other sites More sharing options...
yamie700 Posted December 23, 2006 Share Posted December 23, 2006 Right now I have ecuExplorer running and there is nothing listed in that lower left box, no ports listed. Does it have to be plugged in to the car for things to show up there? How do I install drivers for the cable? Are they on the Cobb CD that came with the AP or do I get them somewhere else? Link to comment Share on other sites More sharing options...
KGreb Posted December 23, 2006 Share Posted December 23, 2006 Sounds like the AP 2.0 cable is not being recognized. Since the AP 2.0 is new, you might be the first person trying this out. I believe Tari needs a virtual com port to work. If Cobb isn't using their USB adapter in VCP mode, you may be out of luck. Link to comment Share on other sites More sharing options...
yamie700 Posted December 23, 2006 Share Posted December 23, 2006 I think it may be a driver issue. I just plugged it into the car again and the new hardware found thing popped up on my PC, I tried to have it load drives from the COBB CD but it didn't find anything. Link to comment Share on other sites More sharing options...
