robsop1 Posted October 26, 2006 Share Posted October 26, 2006 Car has 22000 miles know and noticed I have a shimmy in the steering wheel after a couple of consecutive hards brakes, anyone one else experiencing the same and how did SOA treat it , I am not looking for a skim job. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 26, 2006 Share Posted October 26, 2006 ya...me too...i thought it was because of me at first, but after i replaced it, it happened again... im on the fence aout getting brembos... or just a brake upgrade... but ya... second set of rotors, warped...with no track time ... Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
G.T.Subie Posted October 26, 2006 Share Posted October 26, 2006 It's the stock pads. I had mY rotors cut 3 times undr warranty within 10K miles. Changed the pads and it hasn't come back for 14k. IT"S THE PADS Denial is your best friend Link to comment Share on other sites More sharing options...
stephenahood Posted October 26, 2006 Share Posted October 26, 2006 I had the rotors swapped very early on, 2500 miles, same pads, I now have over 15K miles with no problems, I am very abusive in regards to brakes.... Link to comment Share on other sites More sharing options...
mele63 Posted October 26, 2006 Share Posted October 26, 2006 SOA will fix, expect to be skimmed though Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 26, 2006 Share Posted October 26, 2006 SOA will fix, expect to be skimmed though explain Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
rkl303 Posted October 26, 2006 Share Posted October 26, 2006 I had mine resurfaced...but that was at 25k Miles. I am on HPS now...but I have only been on them for about 6k miles. Link to comment Share on other sites More sharing options...
GTTuner Posted October 26, 2006 Share Posted October 26, 2006 My LGT is the first vehicle I ever owned that made it past 12,000 miles without a pulsation. Right now, at 32k, it still is smooth as glass unless I do several hard stops, then it will pulsate slightly. IMO, it's the pads that are causing the problem. Possible pad transfer to the rotor or just glazed pads. This is covered under the basic 3/36 warranty, they will resurface them. Link to comment Share on other sites More sharing options...
Xenonk Posted October 26, 2006 Share Posted October 26, 2006 pad deposits.. my stock rotors are still good after 36,000 miles of autox and track driving with various brake pads.. it's just pad deposits on the rotor surface.. nothing of a big deal.. if you want to get rid of it, just do longer harder braking and get some of the brake dust off the surface.. or just get the rotors resurfaced.. if you dont want to go through that kind of hassle, just get some better pads the next go around that doesn't leave a lot of brake dust and tracings/hotspots. Keefe Link to comment Share on other sites More sharing options...
spyguy Posted October 26, 2006 Share Posted October 26, 2006 i have 2 legacy GT wagons, and one of them has the "warped" feeling upon hard braking. the other one doesn't experience this at all. i'm convinced its either defective pads and/or rotors. Link to comment Share on other sites More sharing options...
SQC049 Posted October 27, 2006 Share Posted October 27, 2006 I had this as well. Popped up when my car had 2500 miles on it. They cut the rotors and replaced the pads, no problems since. I'm now at 12K miles. Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
mele63 Posted October 27, 2006 Share Posted October 27, 2006 explain He said he didn't want a "skim job" which, I assume, means simply having his rotors resurfaced. I meant to say SOA will fix under warranty, but they will cut the rotors, rather than simply throwing brand new rotors on the car. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 27, 2006 Share Posted October 27, 2006 He said he didn't want a "skim job" which, I assume, means simply having his rotors resurfaced. I meant to say SOA will fix under warranty, but they will cut the rotors, rather than simply throwing brand new rotors on the car. oh ok...ya i figured that... Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
glgraham_2000 Posted November 14, 2006 Share Posted November 14, 2006 I just purchased a used 05 LGT Limited with 15K miles. It does the same thing. From the looks of it, some people are getting covered under warranty even though I have always heard breaks are not. Will the factory warranty cover this? Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2006 Share Posted November 14, 2006 yes Link to comment Share on other sites More sharing options...
subaruowner840 Posted November 23, 2006 Share Posted November 23, 2006 I had the shaking steering wheel around 20K miles in my 05 GT. Took in into dealer and they said roters were warped and needed to be turned. They did it under warranty but asked if I had my tires rotated recently. They had been rotated by Discount Tire about 1-2 months before. Dealer said the rotors could get improperly seated if the lugs aren't tightend corretly. Be careful who you let rotate your tires! Link to comment Share on other sites More sharing options...
deadeye Posted November 23, 2006 Share Posted November 23, 2006 LGT Brakes " Warped Rotors. I have two Subies--No Prob.. BUT, I do recall other cars I have owned. IF you hit a water puddle after hard braking(The rotor is red hot) it WILL warp the rotor... Deadeye Sends Link to comment Share on other sites More sharing options...
Robdownunder Posted November 23, 2006 Share Posted November 23, 2006 My May 2004 GT is now on its third set of pads and rotors fortunately covered under warranty. Mileage 45,000 kms. Rob. Link to comment Share on other sites More sharing options...
mccorry Posted November 23, 2006 Share Posted November 23, 2006 Mine did this.... I re-bedded the brakes really well and it went away. It has been 30K miles since and no brake vibration. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted November 25, 2006 Share Posted November 25, 2006 I had this problem today. What does re-bedded mean? My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
forestir Posted November 25, 2006 Share Posted November 25, 2006 I had the shaking steering wheel around 20K miles in my 05 GT. Took in into dealer and they said roters were warped and needed to be turned. They did it under warranty but asked if I had my tires rotated recently. They had been rotated by Discount Tire about 1-2 months before. Dealer said the rotors could get improperly seated if the lugs aren't tightend corretly. Discount Tire's policy is that they use manual torque wrenches to tighten lug nuts. I confirmed this was true (at least in my one sample) when I went there with my previous car. Link to comment Share on other sites More sharing options...
G.T.Subie Posted November 25, 2006 Share Posted November 25, 2006 I had this problem today. What does re-bedded mean? http://legacygt.com/forums/showthread.php?t=48533 Denial is your best friend Link to comment Share on other sites More sharing options...
SpeedNeeder Posted November 25, 2006 Share Posted November 25, 2006 http://legacygt.com/forums/showthread.php?t=48533 Interesting reading, thanks. I'll try some re-bedding this weekend. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted November 25, 2006 Share Posted November 25, 2006 I got it too, BUT I just replaced the tires and it seemed to have gone away. New pad are on order- HPS. I'll turn the rotors prior to the install 24k. If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
Xenonk Posted November 25, 2006 Share Posted November 25, 2006 ^ i think oem rotors are cheap enough to just buy another pair.. rather than spending the money to shave down old rotors, I rather just buy new ones. Keefe Link to comment Share on other sites More sharing options...
