rudy Posted October 20, 2006 Share Posted October 20, 2006 Still waiting for my 07 GT to arrive. In the meantime, I'm curious if my Garmin Nuvi 350 will be able to fit in the cubby hole so I can close it when parked to make it less visable when the car is parked. The dimensions are as follows: 3.87" W x 2.91" H x 0.87" D (98.3 mm x 73.9 mm x 22.1 mm) For perspective, it's very much palmsized: http://www.handtec.co.uk/garmin_images/nuvi_func.gif I'll probably try and use a mount similar to this one: http://www.roadmapgps.com/models/garmin-nuvi-350/pic0011.jpg Can anyone here point me to where the cubby hole dimensions are posted, or knows them offhand, etc.? Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2006 Share Posted October 20, 2006 search, there is a member who put it in the cubby albeit without door Link to comment Share on other sites More sharing options...
Spinjockey Posted October 22, 2006 Share Posted October 22, 2006 I've got the C550 (pretty much same size) and it will NOT fit in the cubby box. The nuvi may fit in there stored, but you wouldn't see the screen. You might be able to fab up some slide out swivel mount but that take a bit of work. I used the AVO clock relocation kit and removed the bottom part of the cubby box and cut up the vent trim so I still have the door (but no box or clock). Fits perfectly now! I'll try to snap some pictures tomorrow. Note that should be able to keep the clock if you remove the door and box. I had that setup for awhile, but didn't like it being visable (had my last car stolen for contents!). Link to comment Share on other sites More sharing options...
bstieritz_GT Posted October 22, 2006 Share Posted October 22, 2006 I also have a Nuvi 350 and have been trying to find a better location than stuck on my windshield. Cubbyhole seems too small and I'd like to be able to use the door to hide it. Still wish I could get the factory subaru navi system ((drool)). Link to comment Share on other sites More sharing options...
new2subu Posted October 23, 2006 Share Posted October 23, 2006 I also have the Nuvi 350. It will not fit into the cubby. I ran the power wires behind the cubby and suction cup the Nuvi to the floor of the cubby. You will need to remove the rubber mat that sits on the floor of the cubby. I tapped into the cigarette lighter for power behind the dash. I also installed a hard-wired FM modulator and ran that wire into the cubby as well. Now when I play MP3's on the Nuvi, the music comes out of the car's speakers. My passengers were impressed when we were listening to commercial-free music with occasional interruptions that announced the next turn on our journey. Link to comment Share on other sites More sharing options...
Spinjockey Posted October 25, 2006 Share Posted October 25, 2006 Finally remembered to snap some pictures of my beta install of the Garmin C550 GPS in my cubby with the clock relocated. As you can see when the door's closed it's hard to see the GPS, even with the screen on you can barely see it from seated level in the car, outside the car you only see the GPS black bezel (I swapped out the stock silver one). I really only get glare when the sunroofs open or when the sun's low, but it's still pretty easy to read. I used the rubber cover on the bottom of my new cubby but haven't built a true expanded cubby (may never will). This allowed me to adjust the bottom so the GPS is wedged between the back of the cubby top and rubber, so it stays put but is easy to pull out. Also not pictured is the 12v socket is moved up to behind cubby the GPS so it's on accessory power. I also got the external mic and routed it through the dash up the passenger size A piller then through the headliner to the windshield next to the mirror. If I want to use the GPS in another car it's easy to pull out the GPS and power socket (and the mount that stashed back there). Link to comment Share on other sites More sharing options...
BayScoobie Posted December 7, 2006 Share Posted December 7, 2006 Nuvi 350 in cubby hole http://webandrew.com/__pics__/nuvi1.jpg http://webandrew.com/__pics__/nuvi3.jpg ______________________________ Picture Gallery Link to comment Share on other sites More sharing options...
kuoman Posted December 7, 2006 Share Posted December 7, 2006 Nuvi 350 in cubby hole http://webandrew.com/__pics__/nuvi1.jpg http://webandrew.com/__pics__/nuvi3.jpg Nice, care to share how you did it? I have nuvi 350 and would like to install in the cubby Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 7, 2006 Share Posted December 7, 2006 Yeah, that looks nice. The new 660 is the same height but wider. It would probably look even sweeter in there. Link to comment Share on other sites More sharing options...
BayScoobie Posted December 7, 2006 Share Posted December 7, 2006 The mod was done almost a year ago. I'll take me several days to recall the steps and write it up Stay tuned. ______________________________ Picture Gallery Link to comment Share on other sites More sharing options...
kuoman Posted December 8, 2006 Share Posted December 8, 2006 The mod was done almost a year ago. I'll take me several days to recall the steps and write it up Stay tuned. Actually on one of your other post, you did mentioned the how-to waiting for my Nuvi 350 Link to comment Share on other sites More sharing options...
