nekdut Posted October 12, 2006 Share Posted October 12, 2006 I have the typical brake shake from highway speeds, but I have always been careful to not put the ebrake when the brakes are hot, etc. So from what it sounds like, the stock pads are leaving uneven deposits on my rotors. Do I really need new rotors, or can I just get them turned with new pads. Will this problem come back quickly even if I switch the pads out? Link to comment Share on other sites More sharing options...
legacy2005 Posted October 13, 2006 Share Posted October 13, 2006 depending on the mileage, they should be turnable. depending on what brake pad you go with will depend if the pads leaves a deposit. braking force and duration also come into play. Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
nekdut Posted October 13, 2006 Author Share Posted October 13, 2006 35k miles. I will probably go with Hawk Ceramics and upgrade the lines/fluid as well. Link to comment Share on other sites More sharing options...
hadvw Posted October 13, 2006 Share Posted October 13, 2006 35k miles. I will probably go with Hawk Ceramics and upgrade the lines/fluid as well. HURRY to your dealer (if not heavily modded) and get them to check it out. Mine turned the rotors for free under warranty.. HV Link to comment Share on other sites More sharing options...
bobo69 Posted October 13, 2006 Share Posted October 13, 2006 ebrake won't cause a vibration (completely separate from the service brake) but high speed stops will cause pad deposit i have had it but if you drive and brake sensibly it should wear away, the biggest thing is sitting with the brakes on at a stop sign or light after a stop from say 60-70mph, if you arent going to roll take your foot off the brake or press just enough to light up the brake lights. i found this dramatically reduces the depositing. Link to comment Share on other sites More sharing options...
2furious Posted October 13, 2006 Share Posted October 13, 2006 I also got vibration when braking more than 50mph... The dealer turned the rotor for free under warranty. From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
caramall2 Posted October 14, 2006 Share Posted October 14, 2006 I had warped rotors...dealer tried to turn, still had problems. Dealer replaced rotors. With new rotors and good pads (I switched to Endless SS-M) it's been great. I think brakes (and tires if required) should be the first mod on any vehicle that needs it--gotta have good stopping power. Link to comment Share on other sites More sharing options...
nekdut Posted October 14, 2006 Author Share Posted October 14, 2006 Dealer refused based on mileage. They said it has to be 12k or less. This was at Timmons Subaru. Can anyone suggest a decent dealership in Socal that would take care of this for me under warranty? Link to comment Share on other sites More sharing options...
magnetic1 Posted October 14, 2006 Share Posted October 14, 2006 Dealer refused based on mileage. They said it has to be 12k or less. This was at Timmons Subaru. Can anyone suggest a decent dealership in Socal that would take care of this for me under warranty? It'll be hard to find a dealer who will do it when youre close to 36k miles. What may be causing the issue is stock deposits. If this is the case, you can try polishing down the rotor surfaces with something like steel wool, etc. Spray brake cleaner and have at it till all deposits are gone. (Do this while it is cold of course). If I can help with new equipment, please let me know, thanks. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
awdG35killer Posted October 14, 2006 Share Posted October 14, 2006 35k miles. I will probably go with Hawk Ceramics and upgrade the lines/fluid as well. exacly what i did this week, brakes so much better now. i actually didnt have to resuface the rotors tho, they were still smooth at 40k miles. hawk ceramics and techna fit lines with motul fluid. you wont be disappointed Link to comment Share on other sites More sharing options...
zuczek Posted October 15, 2006 Share Posted October 15, 2006 Go to an empty parking lot. Put the car in reverse and accelerate to as much as you feel comfortable driving backwards. Hit the brakes hard!, repeat 2-3 times... No more deposits. Worked like a charm on mine. Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2006 Share Posted October 15, 2006 Brakes are covered until 36k miles under warranty. Call SOA. Link to comment Share on other sites More sharing options...
hondas123 Posted October 15, 2006 Share Posted October 15, 2006 Brakes are covered until 36k miles under warranty. Call SOA. I didn't know that. I thought brakes were considered a wear and tear item that was only covered until 12k? Guess I'll check the warranty book. - The Mortgage Man Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2006 Share Posted October 15, 2006 12k miles is a BS that some ignorant/shady dealers tried to push to quite a few members. 36k/3yrs miles bumper to bumper, that's what it is. There is no portion of the warranty that would be effective until 12k miles only. The only thing I am unsure about is the wheel alignment. Reports are dealers cover it only once with low mileage. Link to comment Share on other sites More sharing options...
