legacy4me Posted October 11, 2006 Share Posted October 11, 2006 I noticed this in my lights as well, found this on another thread..any ideas what i can do to resolve this? mine looks the same as this light on the left... Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 11, 2006 Share Posted October 11, 2006 Eet looka like de boolb wen bad, mon. Link to comment Share on other sites More sharing options...
laz Posted October 11, 2006 Share Posted October 11, 2006 Is that HID on the left and regular on the right? your cutoff looks weird, is that what you are pointing out? X --- Link to comment Share on other sites More sharing options...
mr_luv Posted October 11, 2006 Share Posted October 11, 2006 its the squierl finder, on the cut off sheild it causes a little light to shine into the trees and on to street signs. Mr.350 Link to comment Share on other sites More sharing options...
legacy4me Posted October 11, 2006 Author Share Posted October 11, 2006 Is that HID on the left and regular on the right? your cutoff looks weird, is that what you are pointing out? X In that picture, yes HID on left, regular on right. Im wondering about the black line on the left hand side, but now that you mentioned it, what do you notice about the cutoff? Link to comment Share on other sites More sharing options...
laz Posted October 11, 2006 Share Posted October 11, 2006 I think the cutoff needs to look more like this: http://deexboy.com/albums/album28/IMG_5017.sized.jpg Granted this image is from further away, but I had my car very close to a wall (parking lot) and it always looks straight like in the above pic, with no black lines. X --- Link to comment Share on other sites More sharing options...
NutBucket Posted October 11, 2006 Share Posted October 11, 2006 The pic the OP posted is the same as my cutoff when I'm very close to my garage door. From further back its nice and straight. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 11, 2006 Share Posted October 11, 2006 I noticed this in my lights as well, found this on another thread..any ideas what i can do to resolve this? mine looks the same as this light on the left... turn the bulb around the other way...and im being serious Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
mr_luv Posted October 11, 2006 Share Posted October 11, 2006 correct LLAE is right brown rod on bulb should be facing down. turn the bulb around the other way...and im being serious Mr.350 Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 11, 2006 Share Posted October 11, 2006 correct LLAE is right brown rod on bulb should be facing down. i couldnt figureout what LLAE meant Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
soyboy004 Posted October 11, 2006 Share Posted October 11, 2006 turn the bulb around the other way...and im being serious the beam patterns on both sides are very similar. the right side is a stock halogen bulb without any removal/changes. the left side is the HID bulb fitting in the ONLY way it could. (this means there is only one notch to fit into the housing) possibly the manufacturer mounted the bulb on the bulb holder incorrectly? perhaps this is why i can't do what you say! In the pic below, you see the bulb holder is complete circular on the part shown. on the other side is the portruding notch which fits into the housing like the stock bulb. unfortunately, there is no other way to fit it in. with the notch on the other side, the blue bar thing is above the bulb when mounted, which from what i hear is the correct way to have it. http://i26.photobucket.com/albums/c120/soyboy004/LegacyGT/bulb.jpg Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 11, 2006 Share Posted October 11, 2006 the beam patterns on both sides are very similar. the right side is a stock halogen bulb without any removal/changes. the left side is the HID bulb fitting in the ONLY way it could. (this means there is only one notch to fit into the housing) possibly the manufacturer mounted the bulb on the bulb holder incorrectly? perhaps this is why i can't do what you say! manfufacture made the bulb wrong, but on my stock headlight(no the bulb), there are two notches, so that i can turn the bulb around beam patterns will be similar, the only thing wrong is the the ROD on the HID bulb is facing up instead of down.. im curious as to who makes your HID kit Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
soyboy004 Posted October 11, 2006 Share Posted October 11, 2006 manfufacture made the bulb wrong, but on my stock headlight(no the bulb), there are two notches, so that i can turn the bulb around beam patterns will be similar, the only thing wrong is the the ROD on the HID bulb is facing up instead of down.. im curious as to who makes your HID kit i got the apexcones from therpmstore. i will check the housing again for the dual notches in which to install the bulbs. Link to comment Share on other sites More sharing options...
laz Posted October 11, 2006 Share Posted October 11, 2006 I have seen this on other Legacy's. Maybe the projector is different on the '06s? X --- Link to comment Share on other sites More sharing options...
legacy4me Posted October 12, 2006 Author Share Posted October 12, 2006 I currently have 6000k bulbs. They are a little too 'indigo' for what I was looking for. I knew I should have got then 4,300. Im hoping once I order the 4,300k bulbs, then the projection will be different. Only problem is that the company who makes my kit, the lowest temp they go down to is 5,000k. Im hoping I can buy a set of Apexcone's to put in my kit. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 12, 2006 Share Posted October 12, 2006 I currently have 6000k bulbs. They are a little too 'indigo' for what I was looking for. I knew I should have got then 4,300. Im hoping once I order the 4,300k bulbs, then the projection will be different. Only problem is that the company who makes my kit, the lowest temp they go down to is 5,000k. Im hoping I can buy a set of Apexcone's to put in my kit. buying another temp bulb wont change how the beam is projected, since your still using the same projector... Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 12, 2006 Share Posted October 12, 2006 I have seen this on other Legacy's. Maybe the projector is different on the '06s? X Ok, something that I just remembered... I Have 05 lights on my 06..i bought a spare set of lights (05's) to black out and put on my car.... I have never had the problem, as the H7's that i have are able to be installed with the rod facing down on both sets of lights Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
legacy4me Posted October 13, 2006 Author Share Posted October 13, 2006 What kit and bulbs do you have? I was thinking on getting the different temp. so that mine wont be as purple, also hoping i wouldnt see that black line as much. Can I mix ballasts with other manufacturer's bulbs? Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 13, 2006 Share Posted October 13, 2006 What kit and bulbs do you have? I was thinking on getting the different temp. so that mine wont be as purple, also hoping i wouldnt see that black line as much. Can I mix ballasts with other manufacturer's bulbs? i have two, mcculloch and banzai...as long as the connectors are the same, they will be interchangeable...iv done it numerous times the black line will still be there until you flip the bulb Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
legacy4me Posted October 13, 2006 Author Share Posted October 13, 2006 im new at this. and i didnt install my lights. what do i need to do to properly flip the bulbs? sorry if this is a dumb question. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 13, 2006 Share Posted October 13, 2006 im new at this. and i didnt install my lights. what do i need to do to properly flip the bulbs? sorry if this is a dumb question. turn the bulb so that the rod is facing down Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
laz Posted October 13, 2006 Share Posted October 13, 2006 I have teh XTEC 5000K kit. And I went really close to a wall today and my cutoff was just straight, nothing like yours. X --- Link to comment Share on other sites More sharing options...
legacy4me Posted October 13, 2006 Author Share Posted October 13, 2006 I have teh XTEC 5000K kit. And I went really close to a wall today and my cutoff was just straight, nothing like yours. X Did you have the black line at all? My lights and cutoff are not like the one in the original picture, that picture is one I found that shows the black line. Mine are look like this : ___/---- when against a wall. Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 13, 2006 Share Posted October 13, 2006 I have teh XTEC 5000K kit. And I went really close to a wall today and my cutoff was just straight, nothing like yours. X if your cutoff was just straight, then something is wrong... legacy4me, your cutoff is fine, a little bit of the output is being afected by the rod facing up and thats about it Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
laz Posted October 13, 2006 Share Posted October 13, 2006 Not straight, but like mentioned above. I did not have the black line at all. X --- Link to comment Share on other sites More sharing options...
