Claw Posted September 26, 2006 Share Posted September 26, 2006 I've been having tire/wheel issues ever since I got the tires mounted this spring (BFG KDW2's on PFF7's). At first I thought it was the valve stem, because I used the ones that came with the lug nuts. I replaced those with the traditional rubber pull through ones on Saturday, now both right tires are flat. What gives..? I wish I bought an air compressor or pump so I can at least take the car out of the garage.. I bet if I call Subaru they'll bill it back to me because I've got aftermarket tires and rims. I don't think I should be driving out to a gas station 5 blocks away eh? I don't want to chance hitting something and bending the rim. Link to comment Share on other sites More sharing options...
rougeben83 Posted September 26, 2006 Share Posted September 26, 2006 have a shop check the tire bead for irregularities and the wheel rim for any damage. I'm guessing is you're getting some sort of leak due to the tire not seating in 100% Link to comment Share on other sites More sharing options...
Claw Posted September 26, 2006 Author Share Posted September 26, 2006 K.. will try to do that soon. Thinking of maybe putting on my winter tires on so at least I can get the KDWs looked at. Thanks, Link to comment Share on other sites More sharing options...
