baj Posted September 6, 2006 Share Posted September 6, 2006 My new '06 non-turbo Legacy sometimes revs up to about 2000 RPM for a few seconds after starting it up. Sometimes it goes as high as 3k rpm. This is not immediately when the engine starts, maybe 15 or 30 seconds later, and lasts maybe 10 seconds before settling back to a normal idle. It doesn't always happen, and I think it has only happened when the engine was cold. Has anybody else experienced this? I can't imagine it's normal, never had a car do this before. Link to comment Share on other sites More sharing options...
hondas123 Posted September 6, 2006 Share Posted September 6, 2006 My car does it. (turbo GT)It's almost like it's got a carburator. If I tap the gas...it drops down in idle. Not sure I've seen it go as high as 3k rpm though. Yes it's worse when cold. - The Mortgage Man Link to comment Share on other sites More sharing options...
GT-L Posted September 6, 2006 Share Posted September 6, 2006 its normal for cars to rev higher during cold starts but 3k is a bit too high. Link to comment Share on other sites More sharing options...
SBT Posted September 6, 2006 Share Posted September 6, 2006 Part of it is the cold-start solenoid adding some initial throttle. Could also be your AC cyling on and off if you have turned it on. I know that my LGT (and all my other Subes do too) picks up a few hundred (probably closer to 8-900 RPMs over stock idle) when the AC kicks on. Other than those two things, I'd only be guessing. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 6, 2006 Share Posted September 6, 2006 Rev Yes. 3000 no. Does it only happen when you wear a footware such as boots or large flip flops. Link to comment Share on other sites More sharing options...
ece_tim Posted September 6, 2006 Share Posted September 6, 2006 Sounds normal man, my 10 year old 207K NA Legacy does the same thing EDIT Mine goes to near 3K, but I'll pay attention tomorrow morning and see exactly how high it goes. Link to comment Share on other sites More sharing options...
pillboy Posted September 6, 2006 Share Posted September 6, 2006 Rev Yes. 3000 no. Does it only happen when you wear a footware such as boots or large flip flops. Hasn't school started yet? You should be drunk or studying...or better, both. It is still ugly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 6, 2006 Share Posted September 6, 2006 I had my first class today! Link to comment Share on other sites More sharing options...
Th3Franz Posted September 6, 2006 Share Posted September 6, 2006 I had my first class today! me too. Thankfully it was only one class. 3 tomorrow. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
baj Posted September 6, 2006 Author Share Posted September 6, 2006 Thanks everybody. It is not footware-related. I'm not quite dumb enough to ask "why does my car rev when I push on the gas pedal." If this is normal or at least approximately normal I'll just wait until the first time I'm in for an oil change to ask about it. Link to comment Share on other sites More sharing options...
ece_tim Posted September 6, 2006 Share Posted September 6, 2006 Well I paid attention to my car when I started it this morning - it went up to about 1800RPM and down from there; no where near 3K. 3K is definitely odd, but not something to get too excited about. Def have them check it out at next oil change Link to comment Share on other sites More sharing options...
bobo69 Posted September 6, 2006 Share Posted September 6, 2006 my dad's 06 2.5i revs out of nowhere up really high and then back to normal idle its happened cold its happend warm and its not a footwear problem i was in the car when it happened and completely took my feet off of the pedals cause i thought i was pushing the accellerator accidently Link to comment Share on other sites More sharing options...
DGarr143 Posted December 16, 2009 Share Posted December 16, 2009 This is normal, I just bought an 09 Legacy Limited and it revs after sitting for awhile to about 2000 rpm's or less and then goes back to normal idling after a few seconds. I called the dealership service department and the guy told me that it does this to heat the cat up quicker. Hope this helps. Link to comment Share on other sites More sharing options...
baj Posted December 16, 2009 Author Share Posted December 16, 2009 This is normal, I just bought an 09 Legacy Limited and it revs after sitting for awhile to about 2000 rpm's or less and then goes back to normal idling after a few seconds. I called the dealership service department and the guy told me that it does this to heat the cat up quicker. Hope this helps. I guess I should have posted a follow-up to this but I forgot until this new post came in (guess I am still subscribed). The dealer I was going to at the time I first posted this (3+ years ago) said it was normal. I got sick of the service department there and started going somewhere else. The new dealership checked and found that there was a firmware update for the ECU for this problem, and it has not occurred since then. Link to comment Share on other sites More sharing options...
