midgy_56 Posted September 3, 2006 Share Posted September 3, 2006 I will start off by apologizing if this is posted in the wrong spot. I wasn’t really sure where to post this. I’ve recently started having trouble starting my 98’ Legacy GT LTD. It’s happened to me twice so far when I go to start the car; all I get is a click. I can start it by jump starting it or using a starter/charger. After I did this the first time, the car was fine for a couple of weeks and then it happened again. After I got the jump start it’s been running fine since. I was told that it could be the starter relay. I guess my question is if that sounds correct? If it is, where will I be able to find the relay and how easy is it to fix myself. Thanks in advance for any help. Link to comment Share on other sites More sharing options...
brett s Posted September 3, 2006 Share Posted September 3, 2006 If you can jump start it, it's not the relay - it's more than likely your battery, it's marginal so it still works sometimes. Link to comment Share on other sites More sharing options...
midgy_56 Posted September 12, 2006 Author Share Posted September 12, 2006 Not the battery, it happened again and was able to start it without jumpstarting it. When I turned the key it would click once, I was told once it gets to the clicking point, rapidly turn the key and it would start, I did that and it ended up starting after a couple of seconds of turning the key. Does this sound like the starter? If so, how hard is it to replace the starter? Link to comment Share on other sites More sharing options...
