KNichola Posted August 18, 2006 Share Posted August 18, 2006 I installed Jazzy's AUX input in my stereo for my iPod. With a car charger attached to the iPod I get static through my stereo speakers. Anyone else know how to fix this? I don't know much about audio/electronics, do I possibly need a ground loop interrupt? Link to comment Share on other sites More sharing options...
ScoobyLife Posted August 18, 2006 Share Posted August 18, 2006 Good question, I'll be doing this mod soon enough. Link to comment Share on other sites More sharing options...
recuomo Posted August 18, 2006 Share Posted August 18, 2006 You need a GLI- check out Jazzy's web site for details. Link to comment Share on other sites More sharing options...
recuomo Posted August 18, 2006 Share Posted August 18, 2006 http://www.jazzyengineering.com/ GLI- ground loop interrupt. Link to comment Share on other sites More sharing options...
KNichola Posted August 19, 2006 Author Share Posted August 19, 2006 thanks for the replies. this things sounds great, by the way, for anyone interested. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 19, 2006 Share Posted August 19, 2006 If you're running an iPod, then you probably want a 3.5 mm GLI to reduce the number of connectors. I've only been able to find it on Crutchfield website. http://www.crutchfield.com/S-ZimorUocTlv/cgi-bin/ProdView.asp?search=noise+filter&i=127SNI135 Link to comment Share on other sites More sharing options...
ScoobyLife Posted August 19, 2006 Share Posted August 19, 2006 Nice find! Just have to find one at a lower cost. Link to comment Share on other sites More sharing options...
ScoobyLife Posted August 19, 2006 Share Posted August 19, 2006 After searching, looks like thats going to be the best price. You can find them on Ebay too! Just search for (PAC SNI-1/3.5 Noise Filter). Link to comment Share on other sites More sharing options...
ilh Posted August 20, 2006 Share Posted August 20, 2006 I'm very happy with my PAC SNI-1/3.5 (from Crutchfield) with my Jazzy and iPod! I have no noise of any kind. While you are in there, I recommend burying a Belkin auto kit for iPod under the radio. (It also comes in black.) I spliced into the power going to the cigarette lighter, attached a cigarette power jack from Radio Shack, plugged the Belkin into that, the GLI audio input into Belkin, set the volume on the Belkin so iPod volume matches CD volume, and I couldn't be happier. All of that is tucked under the radio, next to the airbag control module. The audio sounds much better coming through the dock connector as opposed to the headphone jack. Link to comment Share on other sites More sharing options...
tobecontinued Posted August 22, 2006 Share Posted August 22, 2006 I'm very happy with my PAC SNI-1/3.5 (from Crutchfield) with my Jazzy and iPod! I have no noise of any kind. While you are in there, I recommend burying a Belkin auto kit for iPod under the radio. (It also comes in black.) The audio sounds much better coming through the dock connector as opposed to the headphone jack. I'll second that (and suffer buyers remorse because i have a white one) It's odd that some of us experience ground noise and others don't. I had a HK Drive and Play installed, powered from the lighter in the storage. I experienced tremendous ground interference. When i swithced to the Belkin charge / dock output I no longer had the issues. Makes me wonder if there is some type of built in gli seeing as the unit charges and outpus audio. Link to comment Share on other sites More sharing options...
schwinn Posted August 31, 2006 Share Posted August 31, 2006 Or, in most cases, you can simply unplug the power port connection for the iPod or other MP3 device. If run on batteries, you don't create a ground loop, and the problem goes away... Link to comment Share on other sites More sharing options...
JuxtaGT Posted August 31, 2006 Share Posted August 31, 2006 I installed a GLI and still get noise, haven't had a chance to pull it all apart again, mostly I just live with the iPod running on it's own////:confused: Link to comment Share on other sites More sharing options...
crafty Posted September 5, 2006 Share Posted September 5, 2006 I run the jazzy top package with no issues - best upgrade yet Link to comment Share on other sites More sharing options...
BOXRPWR Posted September 5, 2006 Share Posted September 5, 2006 I had feedback that changed pitch/volume with my throttle position. put a GLI in and the problem went away. got it at Radio Shack for about $20 bucks, if I recall right. Link to comment Share on other sites More sharing options...
ScoobyLife Posted September 5, 2006 Share Posted September 5, 2006 I also have a little noise at acceleration after my install. Ordered a PAC SNI-1/3.5 Noise Filter, should have it by Friday. Link to comment Share on other sites More sharing options...
gershon Posted September 2, 2008 Share Posted September 2, 2008 Search for "ground loop" in ebay and you find some for under $10 shipped. Link to comment Share on other sites More sharing options...
