scottmcphee Posted August 5, 2006 Share Posted August 5, 2006 My Legacy is stock 2.5i wagon, non-turbo. I find it wallows a bit in the corners, with more body roll than I'd like. This might have been discussed to death already, please point me... but I'd like to get validated opinions (people who have tried it) for what would be the best single upgrade to the car to tighten it up a bit in corners.. ?? I'm looking for bang-for-the buck and low cost. Is there a "best cheap easy fix" for this? ..and yes, the 17" stock tires are inflated correctly. anti-sway or roll bar thickened? front or back first? shock upgrade? spring upgrade? Are there stock parts of higher-end models, turbo, LTD, etc..? that can be fitted on my lowly 2.5i wagon that would probably make a difference? Thanks Scott Link to comment Share on other sites More sharing options...
Guest Posted August 5, 2006 Share Posted August 5, 2006 Get 05 2.5i fsb, which thicker than 06 2.5i's one (~$50) - one member did it plus JDM GT rsb ($190 shipped from Japan). This is the best bang for buck. This will remove a good amount of body roll. Still the thing will remain floaty, so you have to get better shocks/springs (or at least springs). Springs only are the cheapest, but I would not recommend just springs - stock struts/shocks are crap and lowered springs will just eat them real fast. Few keywords; Bilsteins, pinks, tein, swift, ion, coilovers - search you will find lots of info. And yes, suspension parts except fsb are compatible between 2.5i and GT. Unfortunatelly there are no really cheap suspension upgrades. The cheapest are Bilstein take-offs from Japan, but these are hard to get. Also, don't forget to replace tires if you have crappy (and deadly) RE92. Supposedly 06 2.5i come with Yokohamas, which for sure are better than RE92, anything is. Link to comment Share on other sites More sharing options...
Paul G. Posted August 6, 2006 Share Posted August 6, 2006 Best bang for buck as above--Rear 20mm JDM sway bar, front sway bar from 05 2.5i (GT front bar will not fit). After that you're talking law of diminishing returns--big money for ever decreasing benefits. Just so you know, I have an '05 2.5i wagon with JDM rear sway and it is a totally different animal than it was with the stock 16mm rear bar. Corners flat, rotates well with just a touch of oversteer (just the way I like it), noticeably less wallow in turns. P. Link to comment Share on other sites More sharing options...
bluesuby Posted August 6, 2006 Share Posted August 6, 2006 Any opinions on the Cobb sway bars? Link to comment Share on other sites More sharing options...
Paul G. Posted August 7, 2006 Share Posted August 7, 2006 I don't think anybody makes a front sway that fits a 2.5i. That's why Unclemat recommended an '05 OEM front bar (21mm as opposed to 20 for the '06). Many have been happy with Cobb rear bar, I get the feeling from reading posts that the Cusco is a better fit. JDM bar is somewhat harder to get (AVO or Rallitek), but it is the bar Subaru uses in every other market but ours, and as such goes in like butter, perfect fit, OEM looks. I think you probably can't go wrong with Cusco or JDM, Cobb makes good stuff and should be fine, but there have been reports of the width being slightly off. P. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted August 7, 2006 Share Posted August 7, 2006 I was under the impression that the Cusco fit both the I and the GT? Link to comment Share on other sites More sharing options...
Xenonk Posted August 7, 2006 Share Posted August 7, 2006 tires would be my answer.. Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 7, 2006 Share Posted August 7, 2006 I was under the impression that the Cusco fit both the I and the GT? front sway bars have fitment issues from the 2.5i vs the GT.. I think it has to do with the exhaust work that is in the way.. I dont remember.. Keefe Link to comment Share on other sites More sharing options...
froggert Posted August 8, 2006 Share Posted August 8, 2006 probably a different crossmember. at least that what it was on the older legacys. Link to comment Share on other sites More sharing options...
Paul G. Posted August 8, 2006 Share Posted August 8, 2006 Tires are a good answer but don't address the wallow and roll so much. I keep cars through at least 2 tire changes, so I think of the OEM as "break-in" tires. Second set are always premium tires, third set depends on the condition of the car. Of course, for me a car is just broken in at 50,000 miles!!! New Michelins coming in September. P. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 8, 2006 Share Posted August 8, 2006 Get 05 2.5i fsb, which thicker than 06 2.5i's one (~$50) - ... Any idea what the diameter is? ...Also, don't forget to replace tires if you have crappy (and deadly) RE92. Supposedly 06 2.5i come with Yokohamas, which for sure are better than RE92, anything is. Our '06 came with RE92's. And I've driven worse - e.g., Mich xw4, OEM on our '98. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Paul G. Posted August 8, 2006 Share Posted August 8, 2006 It is my understanding that the '05 2.5i has 21mm FSB, '06 has 20mm FSB. P. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 9, 2006 Share Posted August 9, 2006 Ours is 19 - but then there's the issue of OB v L fitment, at least on the front.... Dunno if anyone's adressed that. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
hawker800mech Posted August 9, 2006 Share Posted August 9, 2006 I bought an 05 LOB fsb (21mm) for my 06 2.5i (20mm) and it fit great. Got the 20mm JDM rsb from Rallitek. Struts and springs are on the agenda for next year. Link to comment Share on other sites More sharing options...
