wcbjr Posted August 4, 2006 Share Posted August 4, 2006 Ok, why in the heck in the voltage on the dimmer backwards from what you would normally think? I have a boost gauge installed now, and it is tapped into the Orange wire (dimmer, not illumination) going into the head unit. When I dim the dash, the gauge gets more voltage and becomes brighter. Now this isn't really a problem since I set it at medium anyways, so the gauge will match. But what the hell?! I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
driggity Posted August 4, 2006 Share Posted August 4, 2006 If this is like it is on the Imprezas (and I believe it is) Subaru controls the dimmer by changing the "ground" voltage. As you dim the gauges the ground voltage increases and your high to low differential decreases. I think that there is a post on scoobymods about making a simple inverter circuit to fix this. Link to comment Share on other sites More sharing options...
GTINNH Posted August 5, 2006 Share Posted August 5, 2006 I found this link, it should help ScoobyMods - Dim Omori Elect. Gauges with OEM dimmer switch Link to comment Share on other sites More sharing options...
GTINNH Posted August 5, 2006 Share Posted August 5, 2006 Does anyone know where to find the Illumination (+) and the Illumination (-) wires? I have a Omori boost gauge comming in a couple of days and would like to do this when I install it. Link to comment Share on other sites More sharing options...
IanKen Posted August 5, 2006 Share Posted August 5, 2006 Subaru Legacy / Outback / Baja radio harness pin-out Link to comment Share on other sites More sharing options...
GTINNH Posted August 5, 2006 Share Posted August 5, 2006 Subaru Legacy / Outback / Baja radio harness pin-out Thats just what I need, Thanks Link to comment Share on other sites More sharing options...
