c-lo Posted August 3, 2006 Share Posted August 3, 2006 was over at PGT's house today. talking about the possible clearance issues once I put the H-techs on. anyone having issues with this? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted August 4, 2006 Share Posted August 4, 2006 When you say clearance, do you mean with the suspension and hitch or just the hitch clearance? I can't add anything on hitch to suspension clearance but I can tell you there isn't much clearance under the hitch and if you lower it an inch you may have problems. When I installed my hitch rack I would drag pulling up some hills. I ended up shimming the hitch and got another inch of clearance but I don't think I could lower the car. Link to comment Share on other sites More sharing options...
c-lo Posted August 4, 2006 Author Share Posted August 4, 2006 When you say clearance, do you mean with the suspension and hitch or just the hitch clearance? I can't add anything on hitch to suspension clearance but I can tell you there isn't much clearance under the hitch and if you lower it an inch you may have problems. When I installed my hitch rack I would drag pulling up some hills. I ended up shimming the hitch and got another inch of clearance but I don't think I could lower the car. yeah, I'm worried I'll be hitting the hitch on every speed bump I go over, every drive way I go into, etc.... 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted August 4, 2006 Share Posted August 4, 2006 I think if you are on level groun d going over speed bumps is OK.....I just know I couldn't turn into my development without bottoming out, with the rack installed...without the rack it is fine. Link to comment Share on other sites More sharing options...
c-lo Posted August 5, 2006 Author Share Posted August 5, 2006 welp, guess I'll just have to see what happens. thanks. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted August 5, 2006 Share Posted August 5, 2006 Let me know how it goes because I was thinking of H-techs Link to comment Share on other sites More sharing options...
